Prop project
Prop project
Looking under the 2.8 a little while back I spotted this split in the rubber on the central joint of the prop shaft.
I'm not sure if the rubber is available on its own but I found a kit for the whole central CV joint so decided to do a refurb. This is the kit
The joint is held together with 6 bolts which need to be removed
My shaft came apart with the bearing cage attached to this side - there are several large ball bearings in this cage.
This section is on a spline and will need a puller or a little brute force to get apart - brute force in my case hence the dented housing!
This is the other half
There is a bolt in the centre which needs to be removed and then the central joint can be pulled free.
This allows access to the central bearing carrier
This should just slide off
The centre breaks down in to 3 components
The rubber section is held in by metal tabs accessed through this hole
Reassembly is the reverse sequence
You will notice on this spline the larger section that is bridged at the top
This helps locate the next section which will only fit one way - there is a larger gap just left of the small cut out that lines up.
Pop the new CV joint over the splines and pack with the grease provided.
Refit all bolts according to torque settings and its ready to go back in the car
Re: Prop project
Great job there Peter and brilliant "how to" photos for anyone thinking of doing this themselves. Very helpful indeed and shows exactly what the job entails.
I had mine sent off by Tickover to get refurbed while they had the axle and gearbox out so just made sense at the time but doing it yourself must give you great satisfaction Peter. Job well done
Re: Prop project
Done few of those before.. Getting the bearings on the slide back in can be fiddley swapped mine out for a single piece last year.
Brand new Uprated and stronger . Delivered for less than £200 from Northwest Props
Re: Prop project
Peter, did you use any 'props' for your "How To" step by step tutorial photos ... ... ...
Re: Prop project
Looks good, Peter, and what a brilliantly detailed explanation of the work.
Where did you buy the CV joint refurb kit? I can't find them online.
Re: Prop project
Hi Andrew,Andrew 2.8i wrote: ↑Sun Oct 11, 2020 12:04 pm Looks good, Peter, and what a brilliantly detailed explanation of the work.
Usual source
https://www.ebay.co.uk/itm/184465835115 ... 4465835115
Re: Prop project
Hi Peter, thanks for the link.Peter-S wrote: ↑Sun Oct 11, 2020 9:28 pm Usual source
I did see that kit but wondered, alright hoped, you might have found something a little cheaper.
Re: Prop project
Nice work Peter, and its red!
Re: Prop project
Aha, might have to look into that!
