Game over" is a message in video games which signals to the player that the game has ended. It is usually received negatively in a situation where continued play is disallowed, such as losing all of one's lives or failing a critical objective. However, it sometimes also appears after the successful completion of a game. The phrase has since been turned into quasi-slang, usually describing an event that will cause significant harm, injury, bad luck, or even death to a person.Major_Tom wrote: ↑Wed Sep 30, 2020 2:17 pmFordoholic Nick wrote: ↑Wed Sep 30, 2020 1:21 pm
Data are characteristics or information, usually numerical, that are collected through observation. In a more technical sense, data are a set of values of qualitative or quantitative variables about one or more persons or objects, while a datum (singular of data) is a single value of a single variable.
Coal powered Capri on Blue Peter
Re: Coal powered Capri on Blue Peter
Doctor Crusher, his condition is worsening!
A crusher is a machine designed to reduce large rocks into smaller rocks, gravel, sand or rock dust.
Crushers may be used to reduce the size, or change the form, of waste materials so they can be more easily disposed of or recycled, or to reduce the size of a solid mix of raw materials (as in rock ore), so that pieces of different composition can be differentiated. Crushing is the process of transferring a force amplified by mechanical advantage through a material made of molecules that bond together more strongly, and resist deformation more, than those in the material being crushed do. Crushing devices hold material between two parallel or tangent solid surfaces, and apply sufficient force to bring the surfaces together to generate enough energy within the material being crushed so that its molecules separate from (fracturing), or change alignment in relation to (deformation), each other. The earliest crushers were hand-held stones, where the weight of the stone provided a boost to muscle power, used against a stone anvil. Querns and mortars are types of these crushing devices.
Actually, this condition could be very useful.
Semicolon.
Semicolon.
The semicolon or semi-colon; is a symbol commonly used as orthographic punctuation. In the English language, a semicolon can be used between two closely related independent clauses, provided they are not already joined by a coordinating conjunction.
One for you Hamish
Tool is an American rock band from Los Angeles. Formed in 1990, the group's line-up includes drummer Danny Carey, guitarist Adam Jones, and vocalist Maynard James Keenan. Justin Chancellor has been the band's bassist since 1995, replacing their original bassist Paul D'Amour.
genuinely useful! Thankyou oracle.Fordoholic Nick wrote: ↑Thu Oct 01, 2020 7:31 pm
An oracle is a person or agency considered to provide wise and insightful counsel or prophetic predictions, most notably including precognition of the future, inspired by deities. As such, it is a form of divination.
