Valve clearance (again)
...so I whipped off the rocker cover again to check I had done the locking nuts up as I am a scatterbrain... and decided I might as well check the inlet valve clearances too. Good job I did as they had all closed up too. But I cant work out how that has happened. Any thoughts? It's running bloody good now!
Re: Valve clearance (again)
Cam or followers wearing out?
Yeah but strangely three out of four exhaust valves were perfect. It's possible I set them wrong to begin with I suppose...... possible..
Sounds like you might some of that head work Paul kindly offered last week....
Damn I was just near you in the Aldershot area on saturday... exploring the remains of the old jet engine testing facility at Pyestock and then an old barracks at Beaconsfield. I'm going to the barracks again on saturday if all goes to plan - how much were you wanting for the head? Is it standard?
I have found that if you lean on the lock nuts ( just to make sure ) the clearance will close up as you tighten them ......by quite a bit .....like if you nip them up , measure the gap and then give them a good tweek you can loose 3-4 thou. I dunno what is "giving" , any how I bought the special locknut spanner that takes a 1/2" drive ( no more taking the carb off ) and torque them up all the same this way I can see how much clearance I loose and thusly can allow for that when setting clearance. If I dont use some lead substitute my ex clearance dissapears at about 1 thou per thousand miles but the intakes dont seem to move much at all.
Yeah I noticed that when I was doing them the other day.. maybe I didn't double check them 9 years ago.
What are the wear points up there? Lobes and the upper surface of the follower.. anywhere else? I have been getting a very, very fine swarf of metal on the magnetic sump plug, like the most expensive silver eyeshadow
for the most fabulous modern gentleman.
The fact that the magnet picks up the swarf sounds like cam and lifter ,but that would cause clearance to increase not close up.
One would reasonably expect the clearances would change uniformaly but ,like you I find one or two significantly different to the others , and not always the same ones each time clearances are checked.......dunno why .
What about wear on the lower surfaces of the followers? Like on their underside. Is that even possible?
I dont think so. Pretty much the only thing that would cause clearances to close up is wear on either the valve or the valve seat and with standard head its usually the valve seat .....well they dont actually have a seat as such , valve contacts the cast iron head and thats why they wear down , unleaded heads have a hardened insert to resist wear.
I recall , mid 80's, we had issues with 750cc Kawasaki motors where the valve stems were stretching enough to close clearances and cause issues.....mind you these engines had only had a couple of thou clearance , not 8 & 10 like the pinto or around 20 thou for a Xflow.
Well the forum has to have a couple of scatterbrains in order to fulfil its diversity quotient.
- Car(s): Ford Capri Cabaret 1.6,Ford Cortina MK5,1992 Ford Sierra Coupe,1988 Ford Sierra Coupe.Ford Sierra XR4i
Mmmm every web site needs an obnoxious Kiwi......or two
