Ford capri 1977 3.0s resto
Re: Ford capri 1977 3.0s resto
Rear bumper finished and back on mirrors back on.door handles too new gasket due to a slight leak .next job is front bumper.rocker covers powder coated.and new screws for the rocker covers.i had bolts on before and i believe theyre supposed to be screws .and i need to change the drivers door catch is not the same as the nearside one so its something else to change up shame really because when i find one il have to have it plated to match the other .might just leave it for the next owner whenever that would be. .ive set the timing with a timing light 14btdc and the car runs shite.pissed about for ages on and off.so i reverted to timing it by ear as ive done before and she now runs mint.tried running her at 10btdc and shite .havnt a clue what thats all about . im thinking she has a different cam in which alters the timing not sure .
Eyup .its been a while.thought id have a little tidy up of the underside ,all suspension ,roll bars ,fuel tank off and back on,.ive tidied all front and back suspension .the last thing to do was bleed the brakes and guess what the bloody brake master cylinder is goosed.so ive stripped it down and im waiting a seal kit.tut theres always a catch.
Oh and sorted the wiring out to the tank as looked crap with masking tape as in the pic.new fittings and heat shrinkin put on .
She’s looking great , I bet your be enjoying them Cornish / Devon roads this year
Thanks jason.its a great place for a blast about until you get stuck behind a tractor haha.il have done 4 years in march.but then im moving back up north .homesick!
Cheers .well the new seals for the brake master cylinder turned up and fitted.shoved back on .and no pedal when bleeding.its not worked! I phoned a mechanic friend and he said you dozy git my cousin refurbs em.so a quick call and he said they bore it out and put an alloy sleeve in and replace everything.so its now on its way up north .ah well
Well its been a while.and ive forgot to update the brake bleeding fiasco..so i took all front suspension ,roll bar etc off cleaned it up ,made new brake pipes .shoved it all back on no brakes.master cylinder refurb still no brakes.so i clamped off side flexi hose still no brakes.clamped nearside ,brakes .so i put it down to bad caliper.but these were new a few years ago.mmmm .so i put new seals in both sides.and still no fecking brakes. I looked at the calipers and the bleed nipples where facing the bottom which i thought was right.but they should be on top!
I had only put the calipers on the wrong sides.new brake pipes as well.what a dick!.swapped em over then new brake pipes boom!i got brakes.what a dozy cnut.haha.so alls well again.lost the pics somehiw nemind. .then i took the headlights out to clean behind them and got a bit carried away so cleaned up all the front end.
a bit of a scotch and some chrome paint
Thanks andrew.shes booked in for a few stonechips and a bubble 7 inches up the door .bit of a strange place but il get it sorted.then il be happy
