What are these holes for? What size bolt?
-JC-
2004 Mazda RX8
Post by -JC- »
The ones next to the inlet manifold, not the top of the dizzy :lol:
Re: What are these holes for? What size bolt?
Probably for when an air conditioner is fitted. Granada models especially that were also fitted with the pinto engine.
-JC-
2004 Mazda RX8
Post by -JC- »
Ah cool, thanks. Yeah it's a later head, was told Sierra.Thinking of trying to mount a bracket there for my megajolt coil pack
How do you manage the oil pump drive if you remove the dizzy ?
I would guess the bracket comes out over the leads and they feed through a suitable cut out in it.
-JC-
2004 Mazda RX8
Post by -JC- »
I'm going to leave the dizzy in place for now, for that reason, and also in case it doesn't work. I think people usually use a cut down shaft and a blanking plug.
Anyone able to hazard a guess at the bolt sizes? Nothing in my box of bits seems close, although it's such random stuff that's not saying much!
Kind of look the same as the manifold studs, but that's just a guess I'm afraid.
-JC-
2004 Mazda RX8
Post by -JC- »
Yeah I did wonder that. Annoyingly I can't find the spare studs I had :banghead:
M8 I would think.
mjcapri
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Post by mjcapri »
Paul G wrote: Mon May 11, 2020 4:17 pm M8 I would think.
Yes they look like M8 x 1.25. Unless they used fine (1.0) pitch. I still have some pinto heads including a late Sierra one but they’re not at the house otherwise I’d check....
-JC-
2004 Mazda RX8
Post by -JC- »
Cool, thanks. Have ordered some online, hopefully they'll do
nigecapri
Post by nigecapri »
Those holes are for mounting a SUPERCHARGER BRACKET :D
I put my coil-pack on the inner wing just next to the washer bottle & run the HT's along under the strut brace, less heat & vibration & keeps the engine tidier.
