What are these holes for? What size bolt?
The ones next to the inlet manifold, not the top of the dizzy
Re: What are these holes for? What size bolt?
Probably for when an air conditioner is fitted. Granada models especially that were also fitted with the pinto engine.
Ah cool, thanks. Yeah it's a later head, was told Sierra.Thinking of trying to mount a bracket there for my megajolt coil pack
How do you manage the oil pump drive if you remove the dizzy ?
I would guess the bracket comes out over the leads and they feed through a suitable cut out in it.
I'm going to leave the dizzy in place for now, for that reason, and also in case it doesn't work. I think people usually use a cut down shaft and a blanking plug.
Anyone able to hazard a guess at the bolt sizes? Nothing in my box of bits seems close, although it's such random stuff that's not saying much!
Kind of look the same as the manifold studs, but that's just a guess I'm afraid.
Yeah I did wonder that. Annoyingly I can't find the spare studs I had
M8 I would think.
Cool, thanks. Have ordered some online, hopefully they'll do
- nigecapri
Those holes are for mounting a SUPERCHARGER BRACKET
I put my coil-pack on the inner wing just next to the washer bottle & run the HT's along under the strut brace, less heat & vibration & keeps the engine tidier.
