Rear wiper
Owent2005
Rear wiper
Post by Owent2005 »
Hello!
Next on the list of unearthing electric issues is my rear window wiper. The motor has two wires, one I traced to the connection at the boot jack, the other as the picture shows goes to nothing! Does the second wire go to earth or a second connection somewhere else?
Thanks,
Owen
Re: Rear wiper
The rear wiper will only work when the boot lid is closed - when you open the boot, on the left hand side there is a small metal disc in the boot itself that connects to a small part of protruding metal (much like the courtesy light on the other side) that is sprung loaded into place.
The metal on the boot needs to be connected to the other part sticking out of the bottom otherwise it wont work. If it still doesn't work when it's closed try sanding both bits to clean them up a bit, and checking the connections to both of these parts
Owent2005
Re: Rear wiper
Post by Owent2005 »
That’s great Danny thanks, I hadn’t noticed that at all, any ideas where the second wire goes to though, does it go to the breaker switch you mentioned?
Owen
Re: Rear wiper
From memory there was an earth that went onto one of the screws holding it in place, and another to the beaker in the boot lid, but without taking my one apart again I can't remember what else it looks like off the top of my head I'm afraid
cheers
Re: Rear wiper
Just thought - do you have the connection on the boot strut? That could be where you other wire should be going to if it's not connected and not working
Re: Rear wiper
Don`t forget, there are 2 power leads to a wiper, one from the `on/off` switch which starts the motion, once moving it`s then powered from the `self park` supply which runs it right through the arc and back to the start (so if it gets back there and the switch is then `off`, it stops in the parked position). IIRC the power through the LH strut is the `self park` power supply, the copper button connector on the tailgate is the `on/off switch` power supply. I`m sure if the strut supply is interrupted you`ll just lose the self park, the motor will run as long as the dash switch is on.
Re: Rear wiper
Not sure but I think that if the wire is off the strut they won't move off park. Beats me why they didn't just feed all the wires ( window heater Inc )thru the rubber hose thing at the top of the door . The wiper would still opperate with the hatch open but I can't see why that would be an issue.....heaps of other cars seem ok with it
Re: Rear wiper
From my experience, if you take the connector off the left strut then the wiper will work but will just stop wherever you switch it off.
Either way, you should have an earth on the body of the motor, a power supply from the 'penny' connector on the left side of the tailgate, and a self park earth attached to the left strut.
Owent2005
Re: Rear wiper
Post by Owent2005 »
Thanks for all the tips, I’ll let you know how I get on when I get chance to look at it next!
Owen
Re: Rear wiper
Bug wrote: Tue Dec 03, 2019 8:49 am From my experience, if you take the connector off the left strut then the wiper will work but will just stop wherever you switch it off.
Yeah, that makes more sense
