Electronic ignition - Ballast resistor
Calovera
Car(s): Capri 1.6l calypso 1981
Post by Calovera »
So, one of my to-do jobs is to get an electronic ignition module stuck in the car, just for the sake of reliability. I will be keeping the points in the boot, just in case, knowing my luck.
Once I've figured out what module to get, I've been reading and slightly confused about the ballast resistance. It's an old-looking coil, so I assume it's the 6v. I understand that the electronic module does away with the resistance, so I'll need a new coil. Is it just as simple as swapping out the old coil for new 12v one, rewiring then timing? Or will I have to locate and get rid of the ballast resistor wiring, which I assume is in the loom somewhere?
Re: Electronic ignition - Ballast resistor
I believe the coil is more likely to be 9v?
Whatever, it is designed to work with the reduced voltage supplied to it by the ballast resistor.
When you turn the key to start it, the ballast resistor is bypassed, through the starter circuit somehow (memory is a bit hazy), to give a big fat 12v to the coil for a better spark. When you let go of the key it drops back to using the ballast resistor.
The resistor is a fat grey wire hidden in the loom that comes across the bulkhead at the back of the engine bay.
What I did was to find the start of that wire, where it is spliced into the standard thickness of wire (about 4 inches along from the fuse box, if memory serves me right). The drop in voltage is basically achieved by making the 12v fight its way through that thick wire to the coil.
I simply spliced a standard thickness length of wire into the loom just before the resistor and ran that to the coil.
I then disconnected and tied back the existing feed connector from the coil and attached the new one in it's place.
By doing it this way it meant I could fit the old coil and the points back and simply swap the connectors around to use the ballasted feed.
Others may have different methods.
Incidentally, I used the Aldon Ignitor system, paired with the unballasted (12v) Flamethrower coil.
:agree: What he said.
STEVEW
Car(s): Ford Capri 2.3S
Project
Post by STEVEW »
Hello Calovero
If you choose to use the Powerspark ignition kit there is information on the Powerspark Ignition – BLOG.
It’s not a case of 12v or 6v coils: the ballast resistor supplies the coil with 6v under normal running conditions, i.e., the ignition switch is in the “run” position.
Upon starting the engine, when the ignition switch is in the “start” position, the ballast resistor is by-passed thus giving 12v to the coil which improves starting. Release the key and the switch springs to “run”: the system again operating through the ballast resistor on 6v.
What is important is the internal primary resistance of the coil. According to Powerspark’s blog this should be about 1.5 Ω, which is measured between the two LT posts. Our coil measured 1.4 Ω, which indicates it's a "ballast" coil.
The other ignition unit I know of, which is reasonably priced is the Akkuspark.
PS. What engine do you have in your Capri?
STEVEW wrote: Thu Nov 07, 2019 7:00 pm It’s not a case of 12v or 6v coils:
I understand what you`re saying and the rest is correct, but there ARE 6v and 12v coils. If you use a 6v coil without a ballast the 12v it will have across it will cause it to overheat. Equally a 12v coil running at 6v will not produce it`s rated voltage on the secondary. The ballast doesn`t `give` 6v to the coil, it is a potential divider, 12v across a 1.5ohm ballast resistor in series with a 1.5ohm primary coil = 6v across each. (Don`t forget 1.5ohm can be a mile of thick wire or a foot of very fine wire, they have the same resistance but can`t carry the same current.)
Calovera
Post by Calovera »
I called up tickover and they seemed sure to not worry about the coil.
I'm also running a 1.6l pinto.
Tickover did mine and I kept the original coil .
STEVEW
Project
Post by STEVEW »
Hello Stevemarl
Thanks for the input.
I’m not saying that there aren’t 6v & 12v coils.Perhaps I should have opened my comment in a better way.
Nevertheless, I wanted to bring “Caloverero’s” attention to the resistance across the terminals, which - as I understand - is important.
As he said that his coil is old and assuming his ignition system is working correctly with the Ford Ballast Resistor cable installed then we can assume it is more than likely,
“...of the ballast resistor type and uses a 6v coil.”**
Hence, checking the resistance across the terminals helps here.
I certainly, wouldn’t remove the Ford ballast cable from the loom.
“The coil is designed to run under normal conditions with a 7 volt supply…”**
I mentioned Powerspark because they quote a figure of 1.5 Ω on their blog, which lies within the 0.95 to 1.60 ohms Primary resistance given in the Ford manual.
They also suggest running a separate fused cable to their ignition kit which is live only with the ignition on.
However, we haven’t got that far yet!
**(Ford Manual).
PS. I didn’t say that the ballast gives 6V to the coil. I wrote,
“…the ballast resistor is by-passed thus giving 12v to the coil…”
And, according to the Ford Manual, under starting conditions full battery power is supplied to the coil via the starter solenoid.
STEVEW wrote: Fri Nov 08, 2019 6:02 pm I didn’t say that the ballast gives 6V to the coil. I
I know I`m being a pedant but you DID say
STEVEW wrote: Thu Nov 07, 2019 7:00 pm the ballast resistor supplies the coil with 6v
That`s what I took issue with, sorry for any misunderstanding.
I gave a very simple description and solution back at the beginning of this thread.
Whilst all the other input is useful to you, why not take on board actual experience and go with what is proven.
I know I'm not about much on here now, but several people will tell you I have a fair to middling experience with Capris (continually from 1985 until about three years back). A quick search would show that I usually manage to give real world advice based on personal experience.
I had maybe 40 Capris since 1985 and looked after each and every one. I certainly would not do anything as a bodge..............and when I did things wrong I made sure everyone on here heard about it so they learned from my mistakes.
So, anyway, it's up to you of course, but I know what I did worked well and would recommend that route. Saves any worries about resistances, voltages etc.
Let me know how you get on ;)
STEVEW
Project
Post by STEVEW »
Hello Bug
You infer that it's best,
"... to give real world advice based on personal experience."
Absolutely spot on. Couldn't agree more.
And, of course, that's why forums such as this one are good to exchange ideas, knowledge and experiences in order to prevent costly mistakes or spending unnecessary cash.
The negative side of forums is that you can never be quite sure how much experience a poster may have.
STEVEW wrote: Tue Nov 12, 2019 4:52 pm Hello Bug
Indeed!
However, I have found in many cases it takes very little time to work it out.
Post by Mr B »
Totally agree with you, that's why every experience/nitemare I have posted on here comes from my personal experience, I've had Capri's that won't start with the bonnet shut to idle speeds going mad for no apparent reason!
You soon get to find out about that though, it doesn't take long before a newbie will realise who the good guys are and that they know what they are talking about, such as Martin (Bug).
sierra3dr
Car(s): Ford Capri Cabaret 1.6,Ford Cortina MK5,1992 Ford Sierra Coupe,1988 Ford Sierra Coupe.Ford Sierra XR4i
Post by sierra3dr »
@Calovera,have you installed it yet? I did the accuspark on my Cortina,can't fault it
Is there not something you can drop straight in ? I have seen kits that apparently you hoik out the points and fit the module into the dizzy and that's it . Unit runs with either the 9v ballast feed , or the 12v starting voltage, that way you don't have to muck about changing coils or ballast wires. For what it's worth I have an Allison ( now made by Mallory USA ) optical kit that has been on every Ford I've owned and has never been fussy about supply voltage. Personally I would rather have a kit that mounts the unit away from engine heat as it seems its heat ( or lack of cooling ) that is the major issue and these things generate their own heat too . Mine has the optical sensor in the dizzy and the switching unit on the inner guard where it remains reasonably cool......probly why it's lasted 30 odd years. Can you buy a 2nd hand sierra dizzy ?
I think the Bosch dizzy is probly the best choice, if you have that luxury , for upgrading
