Weber 32/36 Gasket Drawing
Anyone have or know of a dimensioned or to scale drawing of a Weber 32/36 top gasket. There are several gaskets to be found on the net but haven't seen this one anywhere yet. I can program a new one in following a spare I have but just wondering if there is one already. Thanks.
Re: Weber 32/36 Gasket Drawing
I assume you want to make a new one? Is it worth all the hassle when you can get a new one for a fiver from Webcon?
http://www.webcon.co.uk/shopexd.asp?id=1839
Point taken Paul. Perhaps someone on here has an intact used one that you could copy. It could be a little business if you can exactly copy them and knock a few out to sell.
Thanks Steve, I shall use that, along with my own, to create a spot on standard.
Paul, the 55mm is to the exact centre point of the bolt holes, felt this was better than the outside dimension as that varies from gasket to gasket (overlaps body)
Dunno if I have said before but I scan any gasket that will fit on the scanner (sometimes you can scan the gasket face of the actual part ), cept head gaskets or exhaust gaskets that need to be made outa stuff I can't make , then when I want another gasket I put an A4 sized bit of gasket paper in the printer ( photo paper ....gasket paper, printer can't tell the difference ) print it and cut it out . Just make sure the printer is set to the right scale ,........that never happened to me........any body need some Guzzi rocker gaskets that are 125% the right size
I have exactly the same, a folder full of water pumps, thermostats, carbs etc - anything that`s made of paper. And a set of different diameter punches to make the holes. I find it quite satisfying to make myself (although the carb IS a bit fiddly) But, hell. if someone wants to make perfect CAD, laser cut ones - I`m not going to complain!
Hi res scan of gasket programmed and prototypes machine cut. These will be tested/amended for exact fit then will have a batch in correct material which should do me for life then
Looks good Paul. What material did you use in the end?
You're a clever bloke Paul. Are you going to make a batch and sell them?
That's a nice comment, thank you Paul. I haven't really thought about selling them on, I just wanted a large batch so I can have them to hand when needed. But I can pass them on I guess, to anyone who needs them.
All done and ready to fit, very pleased with how they turned out.
Paul,
lovely job - and you`ve managed to find, and use, one of the few things we still make in this country too! Flexoid?
A job well done!
Yes, you probably could have bought a gasket but there's nothing as satisfying as doing the job yourself. Making it yourself is also the best way to ensure that the part meets your exacting standards.
Thanks guys
That`s one of the great things about cars of this era, there IS so much you can do yourself, you can still get properly involved with the machine.Andrew 2.8i wrote: ↑Tue Nov 05, 2019 12:20 pm there's nothing as satisfying as doing the job yourself.
