Wanted - dip stick and oil filler cap
- jrooney1991
- Car(s): Ford Capri 1.6 Laser - Back on the road!
After the cam cover oil cap and dipstick for a 1600 laser pinto please!
James Roooooooooooooooooooney!
http://www.clappedouttoclassic.blogspot.co.uk
Have a quick look at my Capri's ongoing restoration! You might teach me something!
Re: Wanted - dip stick and oil filler cap
Have you tried the usual places?
Failing that there are a couple on for bith items you're after, though the prices seem to vary a fair bit...
- jrooney1991
Good shout! Found an oil filler cap (NOS as well!) but there appears to be two lengths of dipstick... anyone know which is which? I can’t see why they would vary between the pintos...
I believe that the 2.0 is a slightly taller engine so presumably you need the shorter dipstick for your 1600jrooney1991 wrote: ↑Sat Aug 10, 2019 7:06 pm Good shout! Found an oil filler cap (NOS as well!) but there appears to be two lengths of dipstick... anyone know which is which? I can’t see why they would vary between the pintos...
Do you mean the dipstick is bigger on the 2.0 pintoPeter-S wrote: ↑Sat Aug 10, 2019 9:29 pmI believe that the 2.0 is a slightly taller engine so presumably you need the shorter dipstick for your 1600jrooney1991 wrote: ↑Sat Aug 10, 2019 7:06 pm Good shout! Found an oil filler cap (NOS as well!) but there appears to be two lengths of dipstick... anyone know which is which? I can’t see why they would vary between the pintos...
My dipstick tube has always been loose, is that normal?
I believe they can be pulled out so I guess loose would be possible but probably not `normal` as such? Thinks: if it can be moved up/down how do you know correct position so the stick dips correctly, is there some kind of stop/step?
(Unless I just mistook a "Carry-on" moment )
I've never moved it up and down as such (insert Sid James laugh here), but I can easily rotate it both ways. I have read the same on here from other members too, but always thought it never seemed quite normal.
