The downside to cleaning!
The trouble with cleaning the car is that you tend to look at it a bit more closely. Then you find things. Like a spoiler that is really flexible at one endd as it has been quietly rusting from the inside out!
DSC_0055 by Peter Smith, on Flickr
Which of course is not too good for the paintwork underneath
DSC_0056 by Peter Smith, on Flickr
Guess I've got a bit more work on my hands then
Re: The downside to cleaning!
Oh dear.! A bit of autoglym super resin polish should see that sorted Peter.... hope this helpsPeter-S wrote: ↑Thu Aug 01, 2019 9:48 pm The trouble with cleaning the car is that you tend to look at it a bit more closely. Then you find things. Like a spoiler that is really flexible at one endd as it has been quietly rusting from the inside out!
But yep you are so right Peter. The number of times I have found botched and shortcuts with B112 when I was tidying the engine bay up close and personal... one simple job always seemed to lead me down a completely unexpected turning. Good luck with the repair mate
Very familiar with that look! The spoiler on the S is completely shagged and no-one beforehand seems to have realised/cared so has caused a world of problems underneath
Lucky for me the GL doesn't have a spoiler so one less thing to worry about!
Stick it back on for now Peter and pretend you didn't see it
Just one of the reasons why I will think of doing a job on the car, then jump in instead and zoom off for a drive
You seem to take it all in your stride Peter, I'm sure you will fix it up and will soon be all sorted.
O Pants , it is a water trap there from this we learn not to remove our spoilers .... hope you get it sorted peter and I guess you might have a spare spoiler
I might do
Peter, is that a bolt that`s broken off completely thats sticking out of the tailgate? One of those that go through the back with `plug` covers? I`d never even thought that that could be a problem
It's frightening to see what horrors may be lurking in the unseen areas...
It's a good thing that you spotted it now Peter, as it wouldn't be a good idea to leave rust like that untreated for much longer.
As Jason says, the area under the spoiler appears to be one of the worst water traps on the Capri. Might it be an idea to cover the paint and screw cavities under the spoiler with wax or grease to hopefully prevent any further deterioration?
Indeed it is Steve. Usually they just rust solid in the fitting, much like the screws on front indicators, but this time the rust spread from the spoiler
I think the problem in part is that the rubber on the underside of the spoiler does not always cover the whole of the metal structure within the spoiler and as the rain seems not to drain away freely it can corrode badly. In this case it spread to the tailgate too.Andrew 2.8i wrote: ↑Sat Aug 03, 2019 5:02 pm It's frightening to see what horrors may be lurking in the unseen areas...
The spoiler is very flexible at one end now, the metal has completely dissolved
spoiler by Peter Smith, on Flickr
- nigecapri
Spotted in the nick of time there. Soon be good as new.
Just about perhaps Nige,
I ground the rust out which unfortunately had spread below the spoiler. Jenolite applied
DSC_0057 by Peter Smith, on Flickr
Followed by a good coating of rust paint
DSC_0059 by Peter Smith, on Flickr
Primed and rubbed down
DSC_0061 by Peter Smith, on Flickr
Base coat which I tried to fade in with a small airbrush
DSC_0062 by Peter Smith, on Flickr
and a coat of lacquer and a polish. Looks better in the picture than real life, depends how the light catches it but not too bad
DSC_0066 by Peter Smith, on Flickr
Looks good to me Peter
Looks good to me too, and will look even better once the spoiler is back in position.
Looks great - might have to call upon your services to do all the bits on mine
Yep that's a brilliant repair Peter. Once the spoiler is back on the bigger picture will be even better. Great work mate... Now stop driving your Capris in the rain please
Yes grand job there peter , glad to know we have a paint and rust repair garage opening soon
- nigecapri
There's just a tiny little hardly noticeable spec of rust on my 2.0S, it was there when I bought it but you can't see it if you stand far enough away. Can you see if from where you are Peter?
Do you think Peter took the bumper off to clean behind it?Jasonmarie wrote: ↑Wed Aug 14, 2019 5:38 pm You really have been cleaning ........ peter not to sure if I do like the new look
He seems to have got the cleaning bug now!
