2 questions,
1 how do you tell the difference between front and rear.
2 is it possible to fix the broken stud in them ,
Many thanks guys .
Overiders
- Car(s): D reg 280 , various others
Re: Overiders
I`m fairly certain the front and rear are the same part. It`s quite easy to fit a new stud, just bore out the original hole, cut a piece of threaded studding (M8 IIRC) to length and cement in with JB Weld/chemical metal etc. Just make sure there`s no excess material around the bottom of the stud to prevent overrider sitting flush on the bumper.
Re: Overiders
Thanks I will have a go at it ,someone had mentioned the front and rear were different so thought I would ask the question,thanks for advice much appreciated.
Re: Overiders
Yes they are the same I have had two fitted and the match is really good .
