3.78 litres
Should last a while
Buy in bulk....
Re: Buy in bulk....
Do you use a power hose then Andy or a normal hose with the foam ?
Re: Buy in bulk....
Hi JM.Jasonmarie wrote:Do you use a power hose then Andy or a normal hose with the foam ?
This is a detail spray that I have been using for the last few years. I am running low so worked out a lot cheaper to buy this and put in my trigger bottle
Re: Buy in bulk....
Buying in bulk is definitely the way to go. Unless the goods are perishable, of course!
Do you use the Spray & Shine detail spray instead of Autoglym Rapid Detailer?
Re: Buy in bulk....
Yes agree as buying the little bottles does work out expensive. I use the Autoglym detail spray after a wash .
Re: Buy in bulk....
Hi Andrew,Andrew 2.8i wrote:Buying in bulk is definitely the way to go. Unless the good are perishable, of course!
I tend to find a product I like and stick with it.
I use other Autoglym produts but this is the only detail spray I have used for the last 5 years or so. I get at least 2 seasons from a standard 700ml bottle.
As with the Redex (that's all I have ever used too) everytime I bought a bottle it had gone up in price hence stocking up now
Re: Buy in bulk....
How strange....I use Tesco Body Spray (You would have said it to me)Jasonmarie wrote:I use the Autoglym detail spray after a wash .
Re: Buy in bulk....
very good , I should have seen that one coming ......andyd wrote:How strange....I use Tesco Body Spray (You would have said it to me)Jasonmarie wrote:I use the Autoglym detail spray after a wash .
