Rear wheel arches
- Car(s): D reg 280 , various others
Rear wheel arches
Hi guys Going to be doing them during the holidays, need some advice on how , do I overlap or butt the joints ,some pictures or something to give me a idea on the best way ,thanks guys ,merry Christmas.
https://postimg.cc/gallery/16cq7r9o0/
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Re: Rear wheel arches
Not Capri specific but: https://www.mig-welding.co.uk/wheelarch.htm
You’ll find loads of info over there it’s a good forum (not as good as this one though obviously).
I prefer to butt weld, you could joggle the edges but I’m always wary of it being a water trap. If you can, clamp or somehow fix the new arch in place and cut through it and the old panel together, that way you know the new section will fit. Don’t try and run any beads when your welding it up as the panel will distort, and also be careful of heat build up when your grinding the welds back.
They’re my top tips but I’m sure others will have their own!
Thanks mate the more top tips the better will have a go over the next few days ,much appreciated ,merry Christmas
How did you progress with this? Butt welding is preferable, as mentioned, series of spots first to prevent distortion due to too much heat.
Thanks mate,that’s exactly how I done it butt weld and all finished
https://postimg.cc/gallery/1kw6508fk/
Great job, you must be pleased with that
Trying to work out what car this is - is it a MK1 Granada Ghia Coupe?pbar wrote:How did you progress with this? Butt welding is preferable, as mentioned, series of spots first to prevent distortion due to too much heat.
You're good Paul, it's a 1975 Granada Coupe.
Granada coupe nice ,
Managed it no problem got a new welder ,so was dying to try it out was perfect on body work, thanks guyspbar wrote:Great job, you must be pleased with that
Pleased it went well, looks a good job well done!
