hello!iam after a full stainless exhaust system for my 2,8i .would like manifolds as well if possible!
if not a standard system will do!
2.8i complete exhaust system wanted
Re: 2.8i complete exhaust system wanted
Last I heard Janspeed are only making systems to bulk order now. Don't think anyone does a stainless manifold.....rumone wrote:hello!iam after a full stainless exhaust system for my 2,8i .would like manifolds as well if possible
Longlife or Powerflow Custom made would be an option but will cost.
Good solution https://www.ebay.co.uk/itm/Sportex-Ford ... :rk:4:pf:1
As Andy has said, there aren't many suppliers around. But I had a powerflow fitted to mine - which is good. Longlife will certainly help as well.
Or Sportex as off the shelf.
I was advised (or saw advice) not to fit stainless manifolds. Heat dissipation is an issue with stainless, apparently. Therefore they stay hotter. It's only what I saw / read, not something I know 1st hand.
In fairness though, when I saw some stainless branch manifiolds for sale, they are hugely expensive. Are they worth the cost ? Given road splash / damp / water trapment is unlikely at/in a manifold / downpipe area, I would say that there is nothing extra gained that you get from a stainless set up that far up the pipe.
cheers for that info everyone!think standard may be better!had an ashley system on my last 2.8 but it was awful!are sportex any better?
Recent thread viewtopic.php?f=10&t=52614rumone wrote:cheers for that info everyone!think standard may be better!had an ashley system on my last 2.8 but it was awful!are sportex any better?
They do sound good when fitted.
- petekil
- Car(s): 1984 Capri 2.8i special - bog standard but nice.
Tired but reliable and useful Vauxhall Astra diesel van.
Give these guys a ring Roadrunner Motorsport on 0115 9781173
They managed to supply me with a full stainless steel Janspeed system plus a pair of Janspeed tubular manifolds (mild steel not stainless) for my B reg 2.8i although not exactly cheap at £800 you get what you pay for and once it's done it's done !
I am more than happy with it and the sound is awesome, deep meaty growl but not too much to give you a headache on long trips. I sourced all the other bits needed i.e new hanger rubbers, manifold studs etc from the club at a reasonable cost.
Unless your pretty handy and have access to a ramp / lift I would look at getting a trusted mechanic to fit it as it's one of those jobs that just isn't quite as easy or simple as it looks on paper.
I am a big fan of keeping my Capri as standard as possible but this is definitely one mod/upgrade that I would recommend.
Hope you get sorted and let us know how you get on.
Cheers, Pete K
Cheers, Pete K
Janspeed told me Roadrunner no longer stock Janspeed systems, you have to buy direct 01722 321833.petekil wrote:Hi,
Cheers, Pete K
Great system although not cheap.....
A 1987 2.8i thay are both red
Hi I have a pair off nelly new that where on the car for 3 months a pair of kidney box’s make me a offer you you are interested thanks mark
- Car(s): pontiac formula 400 (restoration project)
there used to be a guy that used to have a garage in Mitch and he is called tinos and his name is Martin he builds hot rods and custom cars and will make you a complete exhaust even manifolds you will have to look him up as not got his no anymore hope it helps
