AndrewAndrew 2.8i wrote:Hi Andy,andyd wrote:I was planning on doing the oil and filter, but thought as it's just sat in the garage I may as well do it in March.
Do you usually change yours this time of year??
Looking from the front of the car, where abouts is the drain plug located and can you get to it wihout jacking the car up??
No, I usually leave the oil change until after the winter, but I felt like a change this year. I personally feel that it doesn't make any real difference when it's done, as long as it's done.
The filler plug is on the right hand side as you look from the front. The sump plug is easy to reach without jacking the car up. The filter can be reached from behind the offside wheel, although you might find it easier to raise the car a little to get to it easier.
What is it?
Re: What is it?
Re: What is it?
No problem. I forgot to ask if your filter is on a hanger, I assumed so? The Ford workshop manual has a diagram that shows the filter screwed directly to the oil cooler, so I would hazard a guess that some cars didn't have them fitted.andyd wrote: Andrew
You can get to the filter from the front of the car if you jack the car up, but with access from the position shown you may not have to. It depends on which tool you use, I suppose.
Re: What is it?
Andrew 2.8i wrote:No problem. I forgot to ask if your filter is on a hanger, I assumed so? The Ford workshop manual has a diagram that shows the filter screwed directly to the oil cooler, so I would hazard a guess that some cars didn't have them fitted.andyd wrote: Andrew
I can see the bottom half of the filter from behind the o s f wheel. My mate has a tool to get it off but not sure which one though.
So looking at your arrow, the sump plug is basically on the r/h side of the sump under the dipstick tube??
Re: What is it?
Yes it is.andyd wrote:So looking at your arrow, the sump plug is basically on the r/h side of the sump under the dipstick tube??
Re: What is it?
That's my next job.Andrew 2.8i wrote:Yes it is.andyd wrote:So looking at your arrow, the sump plug is basically on the r/h side of the sump under the dipstick tube??
This is the sump plug I bought https://www.ebay.co.uk/itm/COLOGNE-V6-D ... SwNYRZmzFa Which washer would you use?
Re: What is it?
Yes very true with the rain , yes with the electric you sell back to the company what you don’t use I can’t remember the cost , also we would have had them on the front what would have stuck out .Andrew 2.8i wrote:We asked about it, but they only give grants to properties with a south facing roof in order to get the maximum return. We don't see as much sun here as you get in the south east. Now, if only there was a way to generate electricity from rainfall we'd be on to a winner!Jasonmarie wrote:Y Our local council was giving grants for solar panels on the roof but they said they would need changing in 7 years time that worked out a lot of money .
I can only guess things will get cheaper also the new houses they are building up the road don’t have any gas going to the houses it’s all electric.
Re: What is it?
Of those, I would use the nylon one. I tend to use a copper one on mine though. I've also got a magnetic sump plug. I'm not sure if it works with regards to attracting metal particles in the oil. However, it does come in handy when draining the oil, because if you accidentally let go of it when unscrewing it, it doesn't fall into the container of used oil but it sticks to the sump.andyd wrote:is is the sump plug I bought https://www.ebay.co.uk/itm/COLOGNE-V6-D ... SwNYRZmzFa Which washer would you use?
Re: What is it?
I thought dropping the sump plug into hot oil was all part of the funAndrew 2.8i wrote:Of those, I would use the nylon one. I tend to use a copper one on mine though. I've also got a magnetic sump plug. I'm not sure if it works with regards to attracting metal particles in the oil. However, it does come in handy when draining the oil, because if you accidentally let go of it when unscrewing it, it doesn't fall into the container of used oil but it sticks to the sump.andyd wrote:is is the sump plug I bought https://www.ebay.co.uk/itm/COLOGNE-V6-D ... SwNYRZmzFa Which washer would you use?
Again Andrew.
Re: What is it?
I take it you usually run the engine beforehand then?andyd wrote:I thought dropping the sump plug into hot oil was all part of the fun
This is the sump plug I bought, if anybody is interested:
https://www.ebay.co.uk/itm/Ford-Capri-R ... :rk:2:pf:0
Re: What is it?
Thanks for the link, I have bookmarked it for future reference.Andrew 2.8i wrote:I take it you usually run the engine beforehand then?andyd wrote:I thought dropping the sump plug into hot oil was all part of the fun
I never used to, but the last few times I have run the engine first as I was led to believe the oil drained better when warm....Old wives tale
You change yours when cold ??
Re: What is it?
I have heard that the oil is thinner when warm, and therefore will drain easier. The question I ask is, does the oil not drain when it's cold? I don't think so. I let it drain, leave it for a bit while I go off and do something else (cup of tea and lunch, usually) and then return to it. As a precaution, I leave myself a note on the steering wheel that says "Do not start", just in case I forget what I was doing when I return from lunch!andyd wrote:I never used to, but the last few times I have run the engine first as I was led to believe the oil drained better when warm....Old wives tale
Yes.andyd wrote:You change yours when cold ??
Re: What is it?
That’s the start of nearing 50 mate when you leave yourself a note must say I also do that ....
Re: What is it?
When you get over 50, by the time you get the paper you've forgotton what you were going to writeJasonmarie wrote:That’s the start of nearing 50 mate when you leave yourself a note must say I also do that ....
Re: What is it?
I'm like that sometimes, I......…...nope. Forgot what I was going to type!andyd wrote:Jasonmarie wrote:When you get over 50, by the time you get the paper you've forgotton what you were going to write
