The Capri failed the MOT today
Not a big surprise to me, but the Capri failed its MOT today.
I've had an issue with the brakes this year where the the brake pedal starts going spongey after a few weeks of the car standing around idle. Thought I'd sorted the problem recently when I changed both rear wheel cylinders that looked like they were past their best and after bleeding the system the brakes worked really well. Got in the car this morning and noticed the pedal had gone soft again
Another thing I had my concerns about was the rear brake bias valve. Whilst changing the rear cylinders I decided to remove the bias valve and bypass it with a short pipe connecting the inlet to the outlet pipes. The brakes worked really well after doing this, so I thought I'd sorted the issue.
Whilst the car was up in the air today I had a good look around at the brake pipes thinking I might have a leaking pipe, but all looked okay. The mechanic thought it could be a problem with the master cylinder, but I changed that just over a year ago. Guess I'll have to change it again, as I can't think what else it could be.
One other thing I've noticed..... When bleeding the rear brakes, which is where the issue is. I start with the usual large bubbles coming through, when these disappear the pedal feels good. If I keep bleeding them I get really fine bubbles coming through, which won't go no matter how long I keep bleeding them. Is this a symptom of an air drawing in through the master cylinder? Its a new one on me. Anyone had anything like this before?
Neil
Neil
Re: The Capri failed the MOT today
Sorry to hear that Neil.sheff wrote:Not a big surprise to me, but the Capri failed its MOT today.
I haven't had this issue before, but if air is getting into the system and you don't have any leaks, I would have thought that it must be the master cylinder that is to blame.
Was the replacement master cylinder a secondhand one?
In case you didn't know, Martin can now supply MCs that are reconditioned to a very high standard.
I'd go along with the diagnosis of the master cylinder too.
When bleeding the brakes if you jack the front of the car a bit higher than the rear this should allow the bias valve to open the flow to the rear a bit more than in the level or nose down position.
If I recall you fitted a new Granny cylinder same as me. Wouldn't expect it to fail that quickly but I'm wondering about the seals between the cylinder and reservoir. Could they be at fault?
Hi Andrew,Andrew 2.8i wrote:Sorry to hear that Neil.sheff wrote:Not a big surprise to me, but the Capri failed its MOT today.
The master cylinder was a new one which I replaced when I uprated the front discs and calipers. I also think it could be the master cylinder, but its frustrating me that its not that old and they are not cheap to replace. I'm probably going to take it off the road for the winter now and might try to rebuild it myself as the seal kits are not too expensive so nothing to lose.
Neil
Cheers for your thoughts on this Paul, looks like its the master cylinder I'm going to be tackling first.Paul G wrote:I'd go along with the diagnosis of the master cylinder too.
Neil
Yes Peter it was the the Granny one. I'm not sure why its failed after not much more than a year and probably no more than a few hundred miles. Makes me wonder what are we buying nowadays, is it just a cheaply made Chinese copy??Peter-S wrote:If I recall you fitted a new Granny cylinder same as me. Wouldn't expect it to fail that quickly but I'm wondering about the seals between the cylinder and reservoir. Could they be at fault?
Theres no evidence of brake fluid leakage from those seals, so not sure if that's the problem. I'll strip the master cylinder down in the next few weeks and possibly I'll see what is causing the problem. I'm hoping its just a damaged seal from being poorly assembled.
Neil
Sorry to hear this too Neil. Hope you get to the bottom of it mate. Yep its a worry if it is the master cylinder which you have not had on all that long. Good luck with rebuilding it mate. If it is down to the quality of assemble it is a worry as you say, but hope it sorts the problem. All the best now.
I had an issue with spongy brakes last year & fitted one of Martins refurbished master cylinders. Haven’t had an issue since, so I would echo the others on this being the issue.
Good luck with the seal kit replacement, has to be worth a try.
I have another batch of the 2.8i master cylinders due back from the refurbishers very soon.Caprifan Rob wrote:I had an issue with spongy brakes last year & fitted one of Martins refurbished master cylinders. Haven’t had an issue since, so I would echo the others on this being the issue.
Cheers Nick... I'm sure I'll get it fixed eventually. These old cars are certainly challenging!Fordoholic Nick wrote:Sorry to hear this too Neil. Hope you get to the bottom of it mate. Yep its a worry if it is the master cylinder which you have not had on all that long. Good luck with rebuilding it mate. If it is down to the quality of assemble it is a worry as you say, but hope it sorts the problem. All the best now.
Cheers Rob.... Looks like everyone is thinking the same with the master cylinder. I'm hoping I find a damaged seal in there when I strip it down. At least then I will get a warm feeling that I've resolved the problem.Caprifan Rob wrote:I had an issue with spongy brakes last year & fitted one of Martins refurbished master cylinders. Haven’t had an issue since, so I would echo the others on this being the issue.
Neil
Thanks Martin, I'll bear you in mind if I don't sort this with replacement seals. Do you have any Granada master cylinders? Or could you get mine refurbished?Caprigear wrote:I have another batch of the 2.8i master cylinders due back from the refurbishers very soon.Caprifan Rob wrote:I had an issue with spongy brakes last year & fitted one of Martins refurbished master cylinders. Haven’t had an issue since, so I would echo the others on this being the issue.
Neil
I’m going to buck the trend here.
Why the master cylinder over the wheel cylinders?
There’s a lot of poorly made aftermarket examples out there.
If it is the master cylinder based on what you’ve described I’d expect the inside of the servo to be wet with brake fluid.
Olly W
Olly W
I found this interesting you-tube film about how they repair master (and wheel) cylinders for old vehicles where new cylinders are not an option. I would guess this is the process that Martin has done to his recon cylinders.
We'll all have to have this done one day when new cylinders of decent quality are no longer available and repair kits alone no longer work.
https://www.youtube.com/watch?v=X36_uEwgjSI
Hi Olly,ollyw wrote:I’m going to buck the trend here.
Olly W
I originally thought it was wheel cylinders which I replaced with a pair of Borg & Beck ones. The old ones were rusty and showing signs that they were starting to leak. It is possible that I bought a bad set but seems strange I have the same problem.
If I bleed the brakes it takes a long time to get air out so I think it is related to an issue nearer the front of the car.
Neil
Interesting video Paul.... Looks a good engineering solution.Paul G wrote:I found this interesting you-tube film about how they repair master (and wheel) cylinders for old vehicles where new cylinders are not an option. I would guess this is the process that Martin has done to his recon cylinders.
I pulled the master cylinder apart at work today and it looks like it has some pitting in the bore when viewed under a powerful microscope.
I've greased the old seals up with some red grease and thinking of refitting it but blanking off the rear port with a bleed nipple to confirm this is the issue. If I can achieve a firm pedal I'll leave it for a few weeks and see if its goes spongy again. If so I'm thinking either a refurb or replacement.
I would'nt recommend buying a new master cylinder off ebay. Judging by mine the quality is not as good as the original fitment. Probably better getting an original refurbished!
