Hi guys,
My GL has suddenly decided that it no longer wants to let the front seats tilt forward... Would this be just because the cable is broken or could there be other issues?
It pulls up and still feels like it has the same resistance on the tilt handle, but if I go to pull the seat forward it just refuses to move... It did it once before and I wiggled it a bit and it worked again but now won't go at all,
Seat won't tilt
Seat won't tilt
Re: Seat won't tilt
Probably the cables have gone Danny. If you can't get new ones, many people seem to bodge the break together with a screw type wiring block connecter.
https://uk.rs-online.com/web/p/products ... lsrc=aw.ds
Re: Seat won't tilt
You'll have to load the beer from the other side then
Re: Seat won't tilt
That's exactly what I was trying to do at the time!Peter-S wrote:You'll have to load the beer from the other side then
Unfortunately both sides have gone Will have to take a look when I get a minute,
Re: Seat won't tilt
Thanks for this link Paul, luckily I seem to have loads of these in my parent's garage, think the old boy before them was a sparky and left loads behind!Paul G wrote:Probably the cables have gone Danny. If you can't get new ones, many people seem to bodge the break together with a screw type wiring block connecter.
A 1987 2.8i thay are both red
Re: Seat won't tilt
There are two cables in the back of the seat you can replace them it’s not to hard I used pushbike brake cables
Last time I did on with recardo seats you have to strip the seat it can be Dunn you just take your time it will take you 90min
A side
A side
Re: Seat won't tilt
As the repair won't be seen anyway, that's a great tip for an easy fix!Paul G wrote: many people seem to bodge the break together with a screw type wiring block connecter.
