Paintwork
Dreamachine
Car(s): Ford capri 2.0 restoration project
Ford focus daily driver
Paintwork
Post by Dreamachine »
I've had my car undercover outside over the winter. And today took the cover off and noticed tiny blisters everywhere.. Anybody know why this has happenend
Re: Paintwork
Dreamachine wrote: Anybody know why this has happenend
It could be that moisture had become trapped between the car and the cover. Have you kept the cover on all through the winter, or did you occasionally take the cover off on a dry day to allow air to circulate?
It might be helpful to post a photo of the blisters. Somebody on here might be able to suggest a cure.
Dreamachine
Re: Paintwork
It's been on all the winter.. Thanks for reply
Re: Paintwork
It’s not red is it ? As the same thing happened to somebody eles on here also I think pbar had the same thing ?
Pictures will help before saying what is best as Andrew said
Re: Paintwork
Has it had any recent paintwork? This can happen when moisture gets trapped under the paint during spraying. It results in tiny pimple like blisters.
Re: Paintwork
Jasonmarie wrote:the same thing happened to somebody eles on here also I think pbar had the same thing ?
That's type 3 water spotting as opposed to blistering. But yes, some pics would be good then we can see what it is.
ollyw
Re: Paintwork
Post by ollyw »
Sounds like trapped moisture.
I’m not completely convinced that external covers work well. I put one on a fixer upper many years ago and it accelerated the rust on the front wings. Found it was better without the cover.
Mind you, does protect from cats etc.
Olly W
Dreamachine
Re: Paintwork
The paintwork is not new... Guessing 6 or 7 years ago...
Not sure how to send pics on here
Re: Paintwork
Dreamachine wrote:The paintwork is not new... Guessing 6 or 7 years ago...
You might find they disappear if you leave the cover off for a while.
How to add pictures;
2. Click Choose Images
Dreamachine
Re: Paintwork
Thanks andy :cool:
Re: Paintwork
Any update on the paint blisters?
Dreamachine
Re: Paintwork
Hi Andy.. Yeah with the cold weather almost gone the blisters seem to have disappeared. Bizarre
Re: Paintwork
Dreamachine wrote:Hi Andy.. Yeah with the cold weather almost gone the blisters seem to have disappeared. Bizarre
Result! :D
fordperv
Car(s): too many
Re: Paintwork
Post by fordperv »
Just don't cover it again or you may not be so lucky, micro blisters are no fun
