2.8i Special bits
ssornai
Car(s): Capri 2.8 Injection Special 1986
Jaguar XF 3.0 V6
2.8i Special bits
Postby ssornai » Thu Nov 23, 2017 11:24 pm
Hey everyone,
Still fairly new here, only my second post..
I’ve finally got my hands on my dream car, this stunning 1986 2.8 injection special.
ImageIMG_8211 by Ford Capri, on Flickr
It’s in great condition but I’m looking to give it a good once over and replace any consumables so looking for some definitive advice as to what’s the best stuff to get!
1. Oil
I know there’s been much debate on this from previous threads so not looking to start WW3 but if someone can point me towards the correct grade and brand for this machine I’d greatly appreciate it!
2. Spark Plugs
Any particular brand worth going for?
3. Air filter
Interested in getting the fancy K&N air filter, is it a straight swap for the original?
4. Coolant
Any brand/type worth recommending?
5. Battery
Don’t think it needs imminent replacing but probably will eventually. Anybody recommend any particular brand?
6. Center caps for these beauties
ImageB1720BDA-5227-4264-9287-53B84E160F82 by Ford Capri, on Flickr
I think they’re off a Brooklands, they look great when fitted but the center caps are cracked inside, I gather they ain’t easy to replace? :shock:
Thanks in advance o wise ones :cheers:
Re: 2.8i Special bits
Postby Andrew 2.8i » Fri Nov 24, 2017 6:35 am
I can't claim to be an "o wise one", but I can tell you the products I use.
1. I've started using Valvoline Racing VR1. It was highly recommended by users of this forum. Whatever brand you use, the common consensus is that 20W50 is the correct grade for the 2.8.
2. I use Champion RN7YC.
4. No particular recommendations here, but a good tip from Fordoholic Nick is that if you live in a hard water area, you can mix the concentrated coolant with ionised water instead of tap water.
5. In case you didn't know, the correct type battery is an 097. I bought a Numax one last year and have experienced no issues.
I hope that helps,
Postby Paul G » Fri Nov 24, 2017 8:59 am
Why don't you just fit a K&N panel air filter to your existing box? Will give better breathing whilst keeping the car standard looking. Plus they only need a clean once in a blue moon rather than replacing every service.
https://www.ebay.co.uk/itm/K-N-Air-Pane ... SwKytZH~i-
Noel
Car(s): Capri 2.8i
Jaguar X Type.
Postby Noel » Fri Nov 24, 2017 10:04 am
Really lovely car.
I will add a +1 for the K&N filter. Don't bother with the K&N "57i" induction kits. Just put the direct replacement type panel filter in the original air intake box. £50 well spent. Mines done 20 years and counting, with the occasional brush out and squirt of oil.
NGK plugs and normal blue antifreeze. Batteries are all much of a muchness but try and get the proper one with the square terminals - motor factors will always be able to get them better than Halfords can - although Halfords batteries are fine as they come with as good a guarantee as anyone elses and they honour them without quibble.
Noel.
ssornai
Jaguar XF 3.0 V6
Postby ssornai » Sun Nov 26, 2017 3:38 am
Thanks for the input guys.
That’s exactly the air filter I was looking at, no interest in any fancy non standard kits. Nice to hear it’s worth the money 8-)
About the battery, excuse the inexperience but what’s the benefit of square battery terminals? And what would be the best thing to fit to easily disconnect the battery when parked up for a while?
This is my first classic car so lots to learn :burnout:
Postby Andrew 2.8i » Sun Nov 26, 2017 6:02 am
ssornai wrote:excuse the inexperience but what’s the benefit of square battery terminals?
The original battery fitted would have been an 097 with square terminals. I see that you currently have convertors fitted to enable a round post battery to be used. That's no problem as the convertors simply unbolt from the original connectors.
Postby Paul G » Sun Nov 26, 2017 8:22 am
Picture of an 097 for sale on ebay. It shows the square terminals which all Fords up to about 1990 had. It just is more original for the car.
https://www.ebay.co.uk/itm/Pline-097-12 ... Sw5cNYTpGP
ssornai
Jaguar XF 3.0 V6
Postby ssornai » Fri Dec 01, 2017 8:17 am
Looks like my car has the round terminals then with!
Another one for the eventual shopping list!
:ebay:
Return to “Q & A”
Who is online
Users browsing this forum: Bing [Bot] and 7 guests
