38 dgas/dgms carburetor issue
Post by Mr B »
I have a 1980 3 litre ghia and have a Weber 38 dgms (manual choke) feeding the fire, only problem is to get a smooth idle the mixture screws need to be almost 7 turns out, bought the carb brand new from Burton power around 3 year's ago, and it's always been the same, according to literature the most they should be is 1 and a half to 2 turns out, checked the idle jet's against an original carb and they match (45''s) also checked for vacuum leaks and none can be found
Any ideas guy's?
Re: 38 dgas/dgms carburetor issue
Define a full turn. If the screw slot is level and you turn it anti clockwise until it is level again that will be half a turn so it will be round once more for a full turn. Apologies if you already realise that but it might mean you are only turning the screw around three turns out, which is about what I've always done with the 38 on my 2.0.
If it's running well and mixture is OK for the MOT tester than may be no need to worry.
Post by Mr B »
Hi Peter, thanks for replying mate, yep nearly 7 whole turns, I use a screw driver with writing on one side of the handle, half a turn writing on bottom full turn writing back up on top if that makes sense, other Weber carbs I've had have never got anywhere near 7 turns out for a smooth idle, totally standard engine only mod is a K & N air cleaner, when I took her for MOT they didn't put her on an emissions test apparently she is too old and doesn't require it
Just a thought, you haven't got more than one spacer plate between the carb and manifold have you?
Post by Mr B »
Hi mate,
just the standard spacer with the pipe connection that goes to the pcv valve on the rocker cover
As you may see elsewhere I've just put a new 38 on my 2.0 as the old one was no longer running well. With your settings in mind I would out the mixture screws 3 full turns and left it to warm up. Seemed to be running reasonably well but I put my Gunson tester on it and it was way too rich. Had to back off by about 1 1/2 turns. I know yours is on a 3.0 but I'm a bit perplexed. Be interesting to know what your emissions are.
nickm
Car(s): Scimitar SE5[previously Capri 3.0Sx2,2.8injection and 5.8V8]
Post by nickm »
Might be worth trying some 50 or 55 idle jets.
One of the DGMS idle jets is different to the DGAS.
Post by Mr B »
Hi Nick,
Funny you should say about the jet's being different, comparing this carb to an original dgas and it seems that the screws to remove the idle jet's are different, the near side screw matches the original dgas but the screw on the off side is much larger and the jet itself is physically bigger than it's counterpart on the opposite side although both jet's are 45's, I just thought it was a design revision made by Weber, do you think this could be part of the puzzle?
Mr B wrote:Hi Nick,
The screws and jets are different on my new dgas as well but both marked as 45s
Post by Mr B »
Just checked Ebay and there is a listing for the bigger jet, the listing does say some dgas/dgms carbs had a bigger jet fitted well physically bigger but still a size 45 but doesn't explain why.....
nickm
Post by nickm »
I don't understand it either.
I only realised when I rejetted my DGMS.
Are the jets definitely size 45 because when I took the jets out of my new
carb the idles were 50s and mains were 135s?
The carb was supposed to have 142 mains and 45 idles.
Clockwork Orange
Car(s): MK2 '78series V8 Laser ..
undergoing major surgery at this time, will be back hopefully soon, better than ever
Post by Clockwork Orange »
nickm wrote:I don't understand it either.
would be better checking all the jets, the emulsion tubes and the air correctors ..
idle jets 45, main jets 142 (145 up to 1976) air correctors 185, tubes F50.
your original DGAS will (should) have been set-up properly, so investigate that, then if the parts are different then order correct sizes for your new carb .. I suggest a known weber dealer, not just any eBay gamble ..
http://www.fastroadcars.co.uk/store/index.php
http://www.webcon.co.uk/
hope that is of help to you
I had a 38/38 with different physically sized jets on a kit car i had a couple of years ago. I asked around and apparently some of them were like that whilst others had the jets the same physical size.
I never quite got to the bottom of why that was but the jets all seem to be available in the bigger size so it doesn't restrict choice when rejetting.
Post by Mr B »
Does seem strange that considering the jet's on both carbs old and new are the same size and yet the mixture screws on the new type of dgas need to almost be fully wound out to get a decent idle yet 1 - 2 turns out was/is adequate on the original dgas
Post by Mr B »
Just a quick update, I think I have solved the mystery, the mixture screws on the new dgas are much much longer than the original dgas mixture screws meaning they have to be turned out alot more to get the same effect, 4 whole turns out on the new type roughly equates to just 1 and half turns on the old type dgas, can't understand why Weber have done this unless my carb was fitted with the wrong mixture screws from the factory......
