3D Printing Parts
3D Printing Parts
Postby pbar » Mon Oct 30, 2017 11:14 am
Watching Car SOS last night, they had an Astra GTE on, very rare model by all accounts, and they needed three wheel centre caps. As they are as rare as rocking horse pooper, they had them copied and 3D printed, then painted up, exact copies therefore of the one cap which they did have. Obviously, unlimited copies can now be made. 3D printing is still in it's infancy and I assume therefore expensive. Although this could be the way forward for these hard to get parts.
I remember years ago, photo printing at home was expensive and making your own CD's/DVD's unheard of. So I think that's quite a positive thing for us all :)
Re: 3D Printing Parts
Postby andyd » Mon Oct 30, 2017 11:46 am
pbar wrote:Watching Car SOS last night, they had an Astra GTE on, very rare model by all accounts, and they needed three wheel centre caps. As they are as rare as rocking horse pooper, they had them copied and 3D printed, then painted up, exact copies therefore of the one cap which they did have. Obviously, unlimited copies can now be made. 3D printing is still in it's infancy and I assume therefore expensive. Although this could be the way forward for these hard to get parts.
I have seen that episode before, and that was a clever way of getting a rare part......But lucky they had one as a sample.
Many cars from that era now have that problem of lack of spares, so hopefully a way forward? Don't know if there is a limit to 3D printing though :?
Postby D366Y » Mon Oct 30, 2017 12:06 pm
You can print almost anything, which is pretty amazing!
I know that a few years back people in the US were kicking up a fuss as someone figured out a way to 3D print all the parts needed to make a fully working gun :shock: I also saw at a university on a site visit once that someone 3D printed a plain cube that was about 30cmx30cm and from the outside was completely natural, but inside there was a staircase printed and you could only tell once you cut it open to show it.
If you can write the code to print it, the printer can do it basically! Though you can only print in plastic, would be pretty handy to do it with metal when I need a new front wing :lol:
Postby pbar » Mon Oct 30, 2017 12:21 pm
D366Y wrote:Though you can only print in plastic, would be pretty handy to do it with metal when I need a new front wing :lol:
You can 3D print in steel also.
Postby D366Y » Mon Oct 30, 2017 12:28 pm
Sweet, I know what I'm buying myself for Christmas!! :lol:
Genuinely though, I think it wouldn't be such a bad idea for a group of people to band together and start reproducing the parts we all need frequently before they all break, and not offer them at massively inflated/unaffordable prices. Like those ruddy indicator stalks!
ESSEXV6ESSEX
Car(s): Car
Postby ESSEXV6ESSEX » Mon Oct 30, 2017 8:56 pm
This is definitely the way we will be buying car parts in the future. 3D printing is far cheaper now then it was. When cars are all electric which they will be, we will only need plastic bits and bobs anyway.
tejb1
Postby tejb1 » Mon Oct 30, 2017 10:17 pm
I suppose the benefits will come in being able to produce one offs without the high setup costs of traditional methods. Sure, there will be the initial task of computerising the part, but after that it's easy. In theory. I'm not familiar enough to know whether the parts will be robust enough long term, mind - that's the telling thing.
Postby Caprifan Rob » Tue Oct 31, 2017 6:26 pm
tejb1 wrote:I'm not familiar enough to know whether the parts will be robust enough long term, mind - that's the telling thing.
No need to worry about that. There are currently some internal aircraft engine parts made with 3D printing. It's clever technology & can only get better. It's the future I tell you :D
Postby Andrew 2.8i » Tue Oct 31, 2017 6:44 pm
It will be good when somebody starts printing 2.8 fuel tanks..... :D
Postby Caprifan Rob » Tue Oct 31, 2017 8:26 pm
Andrew 2.8i wrote:It will be good when somebody starts printing 2.8 fuel tanks..... :D
:agree: Put me down for one of those.
Postby Fordoholic Nick » Wed Nov 01, 2017 6:30 pm
So what Ink Cartridges do you need for this 3D Printing ?
Postby Jasonmarie » Wed Nov 01, 2017 6:50 pm
Sounds good but will it only do plastic ?
Postby Fordoholic Nick » Wed Nov 01, 2017 9:20 pm
Jasonmarie wrote:Sounds good but will it only do plastic ?
pbar wrote:You can 3D print in steel also.
Car(s): 3.0 Ghia
Postby Lord Flasheart » Fri Nov 03, 2017 7:11 am
We have a small 3D printer at work, so far I have had some pegs made that hold the retaining cable in place on the centre arm rest, like the ones that hold the rear parcel shelf strings onto the boot. The Ford fixings are a one time only use, as to remove the fixings you have to push the centre thru & it drops into to bodywork, or into the arm rest cover.
I had some of the centre pegs made with a ball on the end of the centre peg so if removal is needed, you have something to get some pliers or grips on ;)
Also made up some switches for my dads Austin 7, the original Bakerlite ones are not available so we copied the shape & printed some more out in plastic ;)
Postby pbar » Fri Nov 03, 2017 8:58 am
You are actually doing it then, making your own car parts! Excellent.
