Nothing mysterious about that technique, seems to be a very common method with a lot of jobs!Andrew 2.8i wrote:Perhaps that's the mysterious secret technique that was being sought earlier in the thread?Mc Tool wrote:" give it a good twat "! ... what 'd you do ? get your Mrs to sit on it
water pump replacement
Re: water pump replacement
- NaisiaN
- Car(s): 1.6 laser 1986. (Toy)
1.4 Renault 19 TR 1989. (Daily) - Contact:
haha cheers i am a carpentry master nglJasonmarie wrote:Nice to see you have it sorted
Off topic also love the drum pad ...............
Jordan
- NaisiaN
i thought this job might involve lots of skill and finessePaul G wrote:Like I've said in a previous post, I use a long thin chisel and put it on the right edge of one of the flats of the nut then give it a good twat with a large tapping stick. Works on most models, not just Capri's.
Jordan
it does ! , she aint going to just climb up there ..... your going to have to talk her into itNaisiaN wrote:i thought this job might involve lots of skill and finessePaul G wrote:Like I've said in a previous post, I use a long thin chisel and put it on the right edge of one of the flats of the nut then give it a good twat with a large tapping stick. Works on most models, not just Capri's.
- NaisiaN
So I finally got the fan and water pump off! the “paper” seal was just slime.. no wonder it was leaking lol.
Also just out of curiosity does anyone know why the blades on the fan aren’t evenly spaced? I would have thought it would be same as a desk fan for example. A couple blades seem chunkier as well . is there a specific reason for it?
Jordan
To ease removal of the fan shroud and fan belt.NaisiaN wrote:So I finally got the fan and water pump off! the “paper” seal was just slime.. no wonder it was leaking lol.
Did you find a secretive all conquering earth shattering method?NaisiaN wrote:So I finally got the fan and water pump off!
- NaisiaN
Haha I borrowed a pair of lockable grips on the pully with them pushed up against the thermostat housing so the pully wouldn’t move... common sense reallypbar wrote:Did you find a secretive all conquering earth shattering method?NaisiaN wrote:So I finally got the fan and water pump off!
Jordan
- NaisiaN
Just started the car for first time after refitting everything and it red lines instantly. Any ideas what would cause it?. Scared me to death! ... on the bright side there’s no more leaks from water pump
Jordan
Your throttle cable or the linkage on the carb must be jammed by something.NaisiaN wrote:Just started the car for first time after refitting everything and it red lines instantly. Any ideas what would cause it?. Scared me to death! ... on the bright side there’s no more leaks from water pump
- NaisiaN
Ah ok I thought it might be something to do with that but thought I’d ask before I mess around with it.Paul G wrote:Your throttle cable or the linkage on the carb must be jammed by something.NaisiaN wrote:Just started the car for first time after refitting everything and it red lines instantly. Any ideas what would cause it?. Scared me to death! ... on the bright side there’s no more leaks from water pump
Jordan
- NaisiaN
Fixed it! Had a nasty case of sticky flaps. Running sweet now. Thanks for everyone’s help dunno where I’d start without this forum!
Jordan
Nice It's only easy when you know how! Thanks for the info.NaisiaN wrote:Haha I borrowed a pair of lockable grips on the pully with them pushed up against the thermostat housing so the pully wouldn’t move... common sense reallypbar wrote:Did you find a secretive all conquering earth shattering method?NaisiaN wrote:So I finally got the fan and water pump off!
