Starting issue
- Car(s): Ford Capri 2.8i 1986 restoration project, Landrover Discovery Daily driver
Starting issue
If I could pick your knowledgeable brains please,
I have a 1986 2.8i which has always started first time, however on Monday last had to take if for an MOT and it wouldn't start,
I checked the usual suspects spark at the plugs etc. anyway I removed the cold start injector to see if fuel was getting through and yes it would was and low and behold the engine fired up, I switched of straight away then but the injector back in and the engine failed to start, I then disconnected the electrical plug to the cold start injector and again the engine started and run great, connect it and it will not My question is what is the relationship with the supply to the cold start injector and the starting sequence.
Thankyou
Thankyou
Re: Starting issue
http://www.zeepoort.nl/jetronic/K-Jetro ... oting.html
This may help. I would check the warm up reg first as it might be overfuelling the engine from cold and the cold start injector is working fine but by doing that is making the situation worse.
What were the mot emissions like? Was it rich while warm?
Re: Starting issue
Thank you very much for your help Ollyw, I will check it and let you know, the emissions were fine, past mot with no problems.
Re: Starting issue
I thought the cold start was fed by the starter motor only when cranking and earths through the thermo time switch. It should not be spraying when the engine is running.
As the link in ollyw's post says there also is an impulse relay which gives a quick pulse to help starting when hot and maybe this is defective.
Re: Starting issue
Thanks Paul G, Do you happen to know where the impulse relay is ?
Re: Starting issue
I don't know for sure as I've never had a 2.8i, but I would guess it's up under the right hand side of the dash in the relay bank above the bonnet release handle.zakumwest wrote:Thanks Paul G, Do you happen to know where the impulse relay is ?
Edit;- I can't find any pictures or wiring diagrams due to the photobucket balls up, but apparantly the impulse relay was green in colour if the original one was there.
Re: Starting issue
Thanks all, I have to check out the reg and relay will let you know, much appreciated.
Re: Starting issue
Yes, the green relay mentioned is under the dash near the bonnet release.
Re: Starting issue
Thanks all, very much appreciated, I will let you know what I find.
Mines beens stood for a while..the engine turns over but no fuel getting through...plus facet pump noisey
Mines been stood for a while..engines turns over but dosent fire up...facet fuel pump noisy
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Re: Starting issue
Faulty coil maybe?340truck wrote:No fuel gettting through
Anyone spot a clue here??????
Re: Starting issue
Ok thanks..I'll check the coil....should the fuel pump make such a noise
Re: Starting issue
Don't bother with the coil it was just a bit of banter....
I think what Dave was saying is that all signs point to the fuel pump....
Re: Starting issue
Ok thanks
Re: Starting issue
Ok I'm guessing because it's been stood for a while
Re: Starting issue
Just wondered if anyone could help me with this...just fitted a new facet fuel pump...the engine starts when I put fuel in the carb but no feed from the tank...any ideas
Re: Starting issue
Stupid question - have you wired it up the right way and is it connected in the right direction to the fuel pipes.
If that's OK you may have a blockage in the pipes or the pick up on the fuel level sender in the tank may be blocked. I recently had this problem on my kit car - stale fuel had caused gunge to block the pick up.
When you fed fuel into the carb did you just tip it down the throttle body or did you connect up to the fuel inlet and fill the float chamber? The float chamber needle valve is another issue that could stop the carb filling with fuel.
Re: Starting issue
I filled the float chamber...yeah the pipes are the right way...will it make a difference if the car is on a steep slope facing up
Re: Starting issue
There's no getting as far as the carb....like you said could be blocked pipes
