Please please please help!
- Car(s): Fiat Punto 1.2 16v, 4-2-1 De-cat, Custom air induction (by GSR), 8v flexy pipe, Custom Centre Exhaust, "GO" Interior, Port Polish head and throttle body, 17" Sabre Alloys, AK FK Coilovers, Tinted Windows.... Air Freshener :D
Hi guys! I've had a few recent posts on here thanks so much for he replys! You've all helped loads!
I've recently refurbished my capri, new paint job, new pistons, valves etc.. spent quite a bit of money on it.
Anyways I drove 500 miles and had it tuned, drove another 100 miles and now it starts for about 20 seconds and just conkes out... I've recently replaced the starter motor , then the speedo cable and now the oil pressure cable and had to polish some of the earth terminals (turns out I didn't need to replace the starter haha)
Does anyone have any advice to do before I take it In to the garage!
Really annoyed as spent 5k doing it up for summer and now it just sits there breaking down every 5 seconds
Re: Please please please help!
Could be millions of things to be honest from that description, but if it was ok before you had it 'tuned', and now it isn't, I would ask them exactly what they did and tampered with, and start there.anicola02 wrote:
How the hell could I not put the most important thing gun the description?! Haha it's a 2l pinto...340truck wrote:Engine type?
Engine was fine after the tune up untill it sat there for two weeks. I started it one day it runs fine then it shut off and didn't turn back on. But it will start up again if you leave it a day but, again, after 20-30 seconds it'll start misfiring and shut off again
There really isn't enough info for someone to diagnose what the issue could be. Maybe crud in the carb blocking the fuel flow? Especially if they have messed with it with 'tuning' it.
Could it be a blocked fuel pick up in the tank? I recently had this with my kit car after it had been laid up with stale fuel still in the tank. Even with fresh fuel it drove to an mot test OK then broke down twicce on the way home. I isolated the problem down to the fuel pick up and the pick up was blocked. Cleaned it out enough to get home then completely cleaned the pick up and blew out the front to rear pipe with compressed air. Also fitted an inline fuel filter.
Your problem could be a similar one if the car has been laid up for any length of time. When it cuts out take the top off the carb and see if there is fuel in there.
Also is your condenser OK in the distributor?
Could be a sticking float needle in the carb so worth checking and cleaning that as well.anicola02 wrote:How the hell could I not put the most important thing gun the description?! Haha it's a 2l pinto...340truck wrote:Engine type?
Just a thought, check the coil is working. I once had a similar problem after someone else worked on a Pinto engined Capri I had some years ago. He had somehow connected the coil to a full 12 volt feed rather than it's usual lower voltage feed via the ballast resistor. The coil overheated almost immediately when fired up, wouldn't restart unless left for quite some time to cool down again. Connecting it to the correct feed sorted it in seconds once i had realised.
What happened with this?
If it's for a pinto engine I wonder if a pipe has come of on the carb as it sounds like just a air pipe has come off .
It would be good if anicola02 could let us know how he got in.
Asking for ideas is great but actually reporting back on how faults were fixed is the means by which we all learn.
