Pinto starter motor terminals
Thought I'd replace the starter too as it's obviously been struggling. New one only has two terminals (heavy duty and spade connector) old one has those two plus a round push on one. What's the extra one for? Do I need it? Car was originally an auto if that matters and it's still the same starter from when I had the auto box on there
Re: Pinto starter motor terminals
The 3rd one is a feed for the points to boost the power on starting iirc
Well, it worked fine with just the two wires connected. Great to have it up and running again. I'm thinking the extra wire was to do with the neutral-start inhibitor from the old auto gearbox actually.
My manual laser has the 3rd one also and the wire connecting to it im definately sure its to give 12v at the points on cranking
Do all the new starters just have the two terminals then? And if so, what happens with that third wire when fitting the new starter?
Don't know if they all have. I went with a high torque one (powerlite) as my old one was struggling a bit with the higher compression. I've just got it tied up out of the way, in case I need it later!pbar wrote:Do all the new starters just have the two terminals then? And if so, what happens with that third wire when fitting the new starter?
Hmm, fair enough! I have electronic igniton with a coil that runs on 12v all the time so I wouldn't have anything to bypass anyway!fordperv wrote:My manual laser has the 3rd one also and the wire connecting to it im definately sure its to give 12v at the points on cranking
Ah, I see, thanks! Most likely then, a standard starter will be like for like.-JC- wrote:Don't know if they all have. I went with a high torque one (powerlite) as my old one was struggling a bit with the higher compression. I've just got it tied up out of the way, in case I need it later!pbar wrote:Do all the new starters just have the two terminals then? And if so, what happens with that third wire when fitting the new starter?
Yeah, would assume so
