I hope everyone is well.
Wanted: one of those plastic caps that cover the nut at the top of the strut piston? That's the one that sits in the centre of the top mount.
I've had a look on Ebay, but can't find anything that seems to match the shape of the original.
Thanks in advance,
Wanted: Strut Piston Top Nut Plastic Cap.
Re: Wanted: Strut Piston Top Nut Plastic Cap.
Hi Andrew,
Not 100% sure but are they not the same as the wheel nut covers on L/GL models like these ones below?
http://www.ebay.co.uk/itm/MK1-MK2-ESCOR ... OSwLN5WhgJ~
That`s a good find, certainly looks close. Just depends on the size of the strut top nut, I thought it was 17mm?
To be honest I've never taken mine off or measured! I bought a batch for the wheels a while back pretty cheap so if it were me I'd look for some of the wheel ones and stick them on somehow as they weren't that priceystevemarl wrote:That`s a good find, certainly looks close. Just depends on the size of the strut top nut, I thought it was 17mm?
Yep, you`re absolutely right, a blob of silicone and nobody would know the difference.
Alternatively, you could smear the inside with flexible sealant and let it dry, it will give it a rubberised grip but will still be removable.
Hi Danny,D366Y wrote:Not 100% sure but are they not the same as the wheel nut covers on L/GL models like these ones below?
Thanks for the link. Those caps are similar in design to the one I want, I suppose somebody would have to be a right anorak to tell the difference.
IIRC in person they look identical apart from maybe a 2mm difference as suggested above but a few good options to avoid them being loose!Andrew 2.8i wrote:Hi Danny,D366Y wrote:Not 100% sure but are they not the same as the wheel nut covers on L/GL models like these ones below?
Let us know how you get on
- Tickford Man
- Car(s): Tickford + 3 x 2.8i
The strut top ones ARE slightly different size to the GL wheel nut caps.
I have both types and can post.
Not on here very often, so won't see PM, please use regular mail johnocapriman (at) outlook.com
