caprisport 260mm brakes
Ghia15
Car(s): 1981 3.0 Ghia (Restoration Project), 1982 2.0's (Long term project), 1993 BMW E34 520i, 1999 Volvo V70 (Sold to the Parents)
Post by Ghia15 »
Does anyone have any pictures of the caprisport 260mm kit fitted to their capri struts?
Looking for how the brackets fit to the car and how the calliper fit to the brackets as a little stumped atm.
It just seems that the bracket holes for the strut are too small and threaded and the holes for the callipers are too small and smooth.
Also the bracket fouls on the nut for the steering arm.
Just wondering if it is just me or am I missing something.
-JC-
2004 Mazda RX8
Re: caprisport 260mm brakes
Post by -JC- »
Is it that you have the brackets and they don't fit? Or you're trying to work out how they fit so you can make some? If it's the latter, I have a 280 kit somewhere, if I can find it I could take some photos if it'd help? Or sell you the whole kit....? ;)
Does the place you bought them from have a technical helpline that could assist? :whistle:
Sorry, I couldn't resist! :) If you post some photos on here of the issue, somebody might be able to spot something that you might have overlooked.
Andrew 2.8i wrote:Hi,
It was tempting wasn't it Andrew. I nearly suggested emailing them for help yesterday but couldn't quite bring myself to do it :lol:
Beakster
Car(s): 1983 Ford Capri 2.9 24V Cosworth Injection
Post by Beakster »
Yo Jon,
Long time ago, but I remember I had to drill the struts, removing the threads, to make the bolts go through. I also had to grind a bit off the strut somewhere too. Give Andy Craig a shout, he was my mentor for the brake conversion, had the brackets cut and supplied the bolts.
:kebab:
damajin
Car(s): Ford Smax (Daily Drive),
Ford Capri mk3 4.1 V8 (Project),
Ford Puma (track car)
VW Golf (the wife's car)
Post by damajin »
Beakster is right, to fit the brackets you have to drill the original threaded holes out to remove the threads and allow the bracket to be fitted on the rear. From memory you also need to grind / file the two tabs with the threaded holes so the bracket fits flat, if that makes sense. I have the 260 kit but since my struts are off at the moment i cant show it assembled. Sounds like you might need to tweak the brackets on your kit too if it's fouling but do double check you've got everything the right way round before you do.
The conversion is Def worth it, it makes such a difference, it's just the suppliers customer service sucks.
Dansta
Car(s): 1985 2.8i Special
Jaguar F-Pace daily driver
Post by Dansta »
I have just bought the 280 kit and if the 260 is along the same lines, which the kit of bits looks like, then the explanation he gave to me is as follows.
Drill the struts to remove the thread and allow the Allen stud to pass through. Mount the plate behind the strut mount. Use one of the spacer washers between the strut and the plate. You'll probably need to flatten the rear of the mount with a file. Mount the caliper bracket on the plate, using another spacer washer between the plate and the bracket. Fine tune if necesssary with thinner washers.
I'll be fitting in a couple of weeks time I'd say.
