converting opening rear windows to fixed rear windows??
getting some polycarbonate replacement windows coming for the capri...at the moment i have opening rear windows....but the replacement screen has no mounting hole for the catch...i seem to remember that some capris had fixed rear glass...how do i convert mine over to sealed rear windows...?is it just a case of sealing them to the exising rubber seal?....of do they have different mounting brackets...?....cheers...
oh and any pictures would help?
on my laser
which has fixed rear windows, the glass is simply glued/sealed to the metal work of the car, there no other mount or anything. (there was a strip of dense foam between the rear glass on the metal work dunno if it was orginal or not..
then the outer trim clips/ screws on and the same with the inner....
so basically just glue the glass to the cars body work.- gotta get in the right postion though..
- rich_jc
- Car(s): Signal Orange 1980 (W) 2.0 GL ("s" spec) 5 speed
Aye, they are just bonded in place...
If your poly carb ones turn out to be no good, Ive got a pair of glass ones.
Rich
Rich
not sure if mk1 chrome will fit...
basically there are 4 or 5 rivits just below the window in the body work, with some sort of clips... the outer trim snaps into these clips...
so youl have to fit these is you want the trim fitted, mk2 chrome will deffo fit a mk3 shell.
but i thought......
car with opening rear 1/4s have slightly different metalwork round the window aperture compared to ones that dont open. Basically the non opening windows are bigger than the ones that do. Park a laser next to a 2.8 and you should see what I mean.
ah there you go then..
sorry i assumed that the metal work would be the same and ford simply added some form of bracketry to fit the opening windows...
Caspian Blue Sierra XR4i
Stealth Grey Focus RS
Mean Green Fiesta ST-3
Re: ah there you go then..
The fixed windows are bigger than the opening ones. I had a GL with opening rear windows and you could see the difference next to my laser.
Re: converting opening rear windows to fixed rear windows??
you need to remove the extra metalwork that is welded in place as the fixed windows are bigger. Also, I think the exterior rear trim is different. I'm using laser stuff in my TT as the old opening windows always leaked.
A Capri is for life... NOT just for Christmas
- Car(s): 1972 Capri Mk1 3000XL Restoration Project.
Hi There.
I see you are removing the rear windows, is on a Mk1 or Mk2. If its the Mk1 would be verey intersted in buying the Looking leaver hinges and the metal that the rubber mounts on.
Please let me Know
Brian
Tel : 07840 046530
Email : [email protected].
Please let me Know
Brian
Tel : 07840 046530
With the greatest of respect, as it's been over eleven years since the last post on this thread, you are unlikely to receive a response to your request.
I would suggest that you contact Martin at Caprigear https://www.caprigear.co.uk/ or Capri Club International http://www.capriclub.co.uk/ to see if they have the parts you require.
