help my capri wont start
stevepeanut
Car(s): 2.8i is now gone, Driving a mk5 cortina, capri wanted around £1000 price
Post by stevepeanut »
Just got in from work, tired to start my capri to move it and it wont run. It starts for about 2 seconds then dies. If I give it a bit gas on and off the pedal it will run for a few secs, then die again. The fuel pump has been extremely loud since I bought it, whining all the time. Could it have finally given up? or is there anything else I can look at?
Steve
340truck
Car(s): Rat - GONE
Is it....
Post by 340truck »
...a 2.8? If so then I would suspect pink relay under the dash first (controls the fuel pump). Try connecting a battery direct to the terminals of the pump, if the pump runs then try to start the car, if the engine runs the relay is at fault. If the pump does not run on direct 12v then it's knackered. If the pump runs but the engine doesn't, check the ignition, starting by checking for a spark at the plug leads and so on.
Stefan Capri
Car(s): 1983 Ford Capri S 2.9 EFI
does the pump
Post by Stefan Capri »
still operate. can you still hear it? differers from differnt (pink) relays some sound the pump when ign is first turned on. and others sound the pump when you turn the key to activate the starter and stop and then the pump sounds.. does this happen?......stefan
STEVE SB
Car(s): 2.8 (resoration)
MX5
2 Escort estates (oilburners) ONE CUT UP OTHER WAITING FOR SCRAPPING
VOLVO V70
MONDEO ESTATE WORK CAR
I have just had exactly the same problem.
Post by STEVE SB »
I was the fuel pump, as you said the pump has been making a loud noise, this is normaly an indicator that the pump is about to fail. it sounds like yours just has.
stevepeanut
pump
I can still hear the pump making noise, but it doesn't sound very healthy. Dunno if its my ears, but it used to make a high pitch whine, now it sounds very low.
stevepeanut
yes
it is a 2.8i
Stefan Capri
you do atually have
fuel in it and the fuel guage ant fibbing? im just asking coz its such an easy thing to over look. and with no fuel in the tank the sound of the pump will change coz it would be wearing its self out.......stefan
stevepeanut
fuel
hmmmm you might be right there. My speedo isnt working, so also no mile reading, so I dont know how many miles since I last filled up. Fuel gauge is reading just over the top of red. So tomorrow night I am gonna fill up a couple of fuel cans and put them in the car, got to be 100% sure the fuel is ok, before I mess with other things.
Stefan Capri
then it sounds
like you have just about run out of fuel and your sender is earthing somwhere
......stefan
stevepeanut
put some fuel in
got 2 fuel cans, filled em up and put it in the car, still no good. Opened the bonnet to have a look in the air box as I was told there could be a sticking flap in there, and.... the top of the air box was not fixed on...
ie the 5 inch diameter circle bit, with jubilee clip. Rammed it back on, and the car fired up ok!!
340truck
Car(s): Rat - GONE
A common...
Post by 340truck »
...occurence, more often than you think! I have known "professionals" take it off to spray easy start in while cranking and wonder why it still won't start!
Olly__C
haha this happened to me at work the other day
Post by Olly__C »
Id lent my capri to my dad, and something always seems to go wrong when he gets his hands on it
so it was no surprise when he rings me and says " your ******* car wont start, get over here and sort the **** out "
turns out the hose from the airbox had come loose, just as you said
it would start on the cold start valve, but as soon as that stopped the engine would cut out :)
