hI EVERYONE,
does anyone know where I can still buy a new bracket where the bottom of the rear shock absorber mounts?
Are they still available from Ford ?
REAR SHOCK ABSORBER BOTTOM MOUNT BRACKET
- Car(s): Laser and 2.8i
Re: REAR SHOCK ABSORBER BOTTOM MOUNT BRACKET
Isn`t it welded to the axle casing? AFAIK they were not available separately. To replace, you`d need to weld to the axle so the additional fabrication involved in making the brackets out of a bit of box section would be fairly simple.
I am not sure if its welded on, hard to see until you take it all apart...
~It is welded to the axle tube. Have a look at your other post. in Q&A.
This must be where your missing reply was hiding!
