Door Lock: Removal and Reassembly
Re: Door Lock: Removal and Reassembly
Post by Caprigear » Mon Oct 07, 2019 9:30 am
Just go to any tool supplier and buy a set of parallel punches. They're not expensive and you'll get at least half a dozen different punches. I have done this job countless times and have not experienced the issues you have.
Post by Andrew 2.8i » Thu Oct 10, 2019 7:08 pm
Sat Jun 15, 2019 9:40 pm
Your make a good clock / watch restorer
On the subject of clocks, I take it that's your letter in this month's club magazine?
Post by Jasonmarie » Thu Oct 10, 2019 8:44 pm
Yes that’s me , I did that last year . Let’s hope we get the laser forum one in as I did that in May .
Post by D366Y » Sat Oct 19, 2019 8:01 am
So I waited all week for these pins to arrive (from a reputable supplier!) as Martin suggested, first one was too big, bent, second one (1.6mm) perfect size, a gentle tap with a rubber mallet then bent it, tried to straighten it back out - snapped :roll:
I just can't catch a break! :lol:
:banghead:
Post by Andrew 2.8i » Sat Oct 19, 2019 11:58 am
I fell bad for starting the thread now, Danny!
I'm sure it will all come good though....
Can you post a photo of how far you've got? Maybe we might be able to see something that has been overlooked.
Post by D366Y » Mon Oct 21, 2019 9:51 am
Sorry for the delay!
This is how far (or not as it may be) I've come :oops:
Good thing is that I've got my refund for my clearly defective pins, new set on order!
Bad thing is that no matter what I do my pictures decide that their all on the wonk :lol:
Post by andyd » Mon Oct 21, 2019 1:49 pm
This is the sort of :turd: that happens pretty much everytime I try something like this :doh:
Maybe the roll pin is slightly bent therefore any amount of spray etc won't help.
Pics are ok when you click on them
Post by D366Y » Mon Oct 21, 2019 2:13 pm
Weird that they work when you click 'em??
Not a bad shout Andy, last resort is to cut the brass outer section off and weld it back up again but I'd really rather avoid that
Post by Andrew 2.8i » Mon Oct 21, 2019 5:12 pm
It looks like the pin should come out easily from there..... :)
Have you tried gripping the protruding end?
Post by D366Y » Tue Oct 22, 2019 8:54 am
Yup, no luck! it only potrudes by about 2mm, 3 at best so struggling to get any grip on it... new pins come today so will see what happens and let you know!
Post by Peter-S » Tue Oct 22, 2019 12:56 pm
Do you have a vice that you can squeeze it in to try and push the pin back the other way?
Post by D366Y » Tue Oct 22, 2019 1:26 pm
Not a bad shout, not thought of that!
I do have a small vice, not sure if we have a bigger one somewhere or not, if not by brother is a chippie so could always ask him if he has a bigger one!
Will give that a bash as well :)
New Stanley forged chrome vanadium steel pins have arrived so fingers crossed I start getting somewhere soon
Post by Andrew 2.8i » Tue Oct 22, 2019 4:30 pm
You don't want the forged ones, you need genuine pins.... :lol:
:goodluck: I hope they do the trick!
Post by D366Y » Thu Oct 24, 2019 8:19 am
It worked! Got the drift pin, delicately tapped it with rubber mallet, the pin came more or less straight out :lol:
Obviously the first ones just must have been shit!!
Thanks for the suggestion from Martin to get proper pins, and also for offering to help with the parts if I couldn't make it work :)
Post by pbar » Thu Oct 24, 2019 2:08 pm
I've been following this thread like a TV soap addict glued to the box awaiting Emmerdale's next instalment. So I'm pleased to see that piece of good news Danny :) You must be relieved.
Post by andyd » Thu Oct 24, 2019 2:14 pm
I've been following this thread like a TV soap addict glued to the box awaiting Emmerdale's next disaster. So I'm pleased to see that piece of good news Danny :) You must be relieved.
Good news Danny :cheers:
Paul, does Amos still run the Woolpack :D
Post by pbar » Thu Oct 24, 2019 2:15 pm
Neigh Mr. Wilks!
Post by andyd » Thu Oct 24, 2019 2:19 pm
Neigh Mr. Wilks!
:wave:
Post by D366Y » Thu Oct 24, 2019 3:02 pm
Just glad to be done with this small saga so I can get stuck on step 2 instead of being stuck right at the start :lol:
Post by Andrew 2.8i » Thu Oct 24, 2019 3:59 pm
It worked!
Good work, fella! :D
Dare we ask what stage 2 involves?
