need new chassis data plate? help!!
- Car(s): Ford Capri 2.0s, Glacia blue.
hi, i need a new data plate that belongs on the front of engine bay o/s. does anyone know where i can get a new one made to suit the resto ? thanks
- Car(s): 3.0 Ghia
Re: need new chassis data plate? help!!
That's not the correct one for a mk3, sadly. As far as I know, nobody makes the correct repro VIN plates for the mark 3. NOS items used to pop up for sale every now again on Ebay, but I haven't seen one for a while.Lord Flasheart wrote:https://www.ebay.co.uk/itm/Classic-Ford ... SwR6RaLpI0
Early mk3’s have the same plates as late mk2’s, both assembled in Germany I think they may change around 81. The one in the image looks correct for an early mk3, I got one for mine so I know you can get them, I may have got it from classic plates in Pinner
- Car(s): 3.0 Ghia
It was more for the sellers details than the actual item.
Give them a call, I have in the past for stuff that was similar to what I was after, though not the item that was for sale & they came up trumps …. cant hurt getting in touch.
Or you could try these, they might be able to point you in the right direction
https://vinplatetag.co.uk/contact/?v=79cba1185463
http://www.classic-plates.com/
http://vin-plate.co.uk/ford_plates.html
http://www.retro-uk.com/page033.htm
In addition to the helpful suggestions above, it might be a good idea to search through the completed auctions on Ebay. That might give you more leads to chase up some potential sellers.
- Car(s): 3.0 Ghia
Another good planAndrew 2.8i wrote:In addition to the helpful suggestions above, it might be a good idea to search through the completed auctions on Ebay. That might give you more leads to chase up some potential sellers.
I wasn't sure about that, I assume that the style of the VIN plate changed the same time that that the stamped chassis number moved to the driver's floorpan?Arnoldhar wrote:Early mk3’s have the same plates as late mk2’s, both assembled in Germany I think they may change around 81.
The OP has posted a photo of an '83/'84 S on an A plate, I assume that's the car that the VIN plate is needed for.
Yes mate mine is A90PNO, 2.0s 1983! Thanks all for the sugestions, i didnt have a clue!Andrew 2.8i wrote:I wasn't sure about that, I assume that the style of the VIN plate changed the same time that that the stamped chassis number moved to the driver's floorpan?Arnoldhar wrote:Early mk3’s have the same plates as late mk2’s, both assembled in Germany I think they may change around 81.
https://www.ebay.co.uk/itm/FORD-CHASSIS ... SwSrNaHHo7Capri&Corona wrote:hi, i need a new data plate that belongs on the front of engine bay o/s. does anyone know where i can get a new one made to suit the resto ? thanks
