oil spray bar replacement and change of oil grade
Re: oil spray bar replacement and change of oil grade
3 Litre Power wrote:VR1 is a good oil for your Pinto, better than most Mineral 20W-50s out there ( Modern Specs : API SM and ACEA A3/B4 ) and it has 1300 parts per million of ZDDP ( a Zinc and Phosphorous compund ) which is important for flat tappet cams to prevent wear like the ones in all Capri engines ( the concentration has been reduced in a lot of oils because it can damage catalytic converters ), and there have been a lot of camshaft failures happening in the past years because of it, originally they were spec'd for a 10W-40, but it will be fine on 20W-50 IF you are gentle to the engine when it's cold.
Hi 3 Litre,
Thanks for your info fella. I remember reading a previous thread you did on oils which was very informative indeed. Defo sounds like Valvoline is s good choice for my Pinto, but would expect nothing less from a recommendation from Dave (Smoke Em) :)
Thanks again
Fordoholic Nick wrote:Ps Andrew I use Autoglym Super Cam/Valve Polish
I wouldn't disbelieve it...... :)
Well you concours chaps set such a high standard :wave:
sheff wrote:Nick,
That is a very clean engine under the rocker cover! That is a good indication that it has been well maintained over the years a credit to you and the previous owners :applaud:
Out of interest, do you know if it is the original engine?
Neil
Too true that's clean, probably cleaner than my arsehole! :lol:
looks great Nicks and thanks for posting, always like these little maintenance bits to see what everyone does
D366Y wrote:Too true that's clean, probably cleaner than my arsehole!
:shock: Ermmm....only bit of advice I can offer Danny is try some of these fella...might just help you out and as they are Autoglym sure to do a great job ! If symptoms persist stop using and consult your doctor :lol:
http://www.ebay.co.uk/itm/Autoglym-Samc ... Swu4BVjQHH
D366Y wrote:looks great Nicks and thanks for posting, always like these little maintenance bits to see what everyone does
Thanks Danny. Much appreciated ! Just another little job I can tick off the list mate. I really enjoy these jobs especially when you can see it as only being a good thing for the Pinto. I had been meaning to try Valvoline Racing 20/50 for a while since Dave recommended it to me. Does seem very good oil indeed. I thought that the oil spray bar was worth doing as B112 still had the original one from when I bought it 10yrs ago. Don't know how long it had been fitted before then. Was prob ok and I know they can be cleaned and reused but as its such an easy job it just made sense to fit a new one alongside changing the oil grade to 20/50.
All the best fella,
Fordoholic Nick wrote:Image
Better get yourself one of these too Danny........ :lol:
