Nothing too thrilling but one of those jobs I aint done before so thought I would pop up a very simple run through for anyone like me who aint done this. The struts I had fitted were on their last legs and had lost their "power". Very hit and miss whether they would hold up the tailgate...not very good, and not very safe
new ones on bottom, old ones on top
to remove the old ones you have to prise out a locking tab then a gentle tap to release the strut from the tailgate "ball joint" fixing. Make sure the heated rear window connections are all removed first !
the struts I got from Martin had these end fittings held in place with a metal circlip...
circlip removed so can now unscrew the fitting
could now fit the old fitting onto the new strut. the threads were a bit fiddly and very tight, but with a bit of "fiddling" got them on nice and secure!
other end now
then fitted them back onto the tailgate. gentle tap to get them on the ball joint then tap the fixing tab back in, then reconnect the wiring connectors for the heated window
They work an absolute treat ! The ones I had before were terrible compared to these. With these new ones fitted I now only have to open the tailgate about a third/halfway for the struts to take over and lift it "automatically" ! Very happy how its turned out.
I shot a short video link to show how well they work, but it was getting late and don't think I fitted the parcel shelf support pole properly as its "creaking loudly" when it opens
Click on the picture to bring up the video link...
Anyhow chaps, as said not a major project but one of those jobs if you aint done before might be quite useful to know how to do it.
PS With the struts removed I did not realise how heavy the tailgate actually is !!
