Capri V8 Project
- Eurostang
- Car(s): MK3 Capri V8 (Project)
MR2 SW20 (Missus's)
Laguna II GT 205 (Daily super-bus)
Capri V8 Project
Hi all,
After moving to a new home and now having a garage I figure it's time to finally attempt what I've always wanted, a V8 in my Capri!
The bike carb & cam was great fun but left me wanting more, and the bodywork is starting to look tired so I'm going to tie in fitting new wings, fully painting the car while the engine is out.
Please bear in mind I'm no mechanic and this is purely a hobby so I'm destined to make some stupid decisions and will probably end up asking for help with quite a few things!
I've actually started the project in October, here are some photos and videos of the project from then onwards;
A few videos from this update:
Watch my V8 Capri Project on YouTube! [url]https://www.youtube.com/playlist?list=P ... WZv_Ps/url]
"Nothing better than seeing your own car next to you"
- MattMe
- Car(s): Mk3 2.8 injection
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
Re: Capri V8 Project
Looks like a good project
I've had 3.9 Rover V8 running a 4 barrel Holly carb, and it was lots of fun in a Capri I can assure you that. Yeah, they don't have loads of BHP, but they do have plenty of torque for a Capri. That along with all the other things you mentioned - light, cheap, availability, parts etc etc. Not really a sound financial investment to tune them, other than boring out or using stroker kits. But above all they sound awesome
As for mounting, you could just weld up something to drop it on the standard cross member mounts pretty easy. Not sure about sump clearances though.
Make sure it's as close to the back of the 'bay as you can get it. Have you considered what you're going to do with the tunnel? I think most conversions would have cut out the top of the tunnel to get the block as close to the bulkhead as possible and cater for the 'box. Never seen an RX-8 'box, so can't comment on how they would fit, but I assume you'll use a standard bellhousing?
Not sure what the model is but my box was from an SD1. Was nice and clicky, just welded a new stick for it so the knob was where I wanted it.
As for PAS, you could either do exactly as you said and get a 2.8 rack or just drop the pump from the engine and get a shorter belt. Might be a quicker/easier way than faffing on with new racks etc.
I think if you've got the time and patience, and someone to show you the ropes, learning to weld will be an invaluable skill. I wish I'd spent more time learning it personally.
Good luck with it all and keep us up to date
- Eurostang
MR2 SW20 (Missus's)
Thank you that's some helpful feedback!MattMe wrote:Looks like a good project
Yes the fact they're so available, light, simple to work on and make a decent amount of power with a 4bbl carb and cam; what's not to love! And that noise!
I too am using a Holley 4bbl carb, 390cfm which I'll be rebuilding, here's some pics!
As for the gearbox; the RX8 5 and 6 speed boxes seem to becoming a very popular box to use with a classic Ford. The splines match on the shafts and they're practically the same size as the Type 9 which means no cutting the transmission tunnel and no need to lengthen or shorten your propshaft.
Here's a pic of them side by side:
Here's how the ratios will look with 2.8 axle gears;
I'll just need an adapter plate to mate it to the RV8 bellhousing, fabricate the gearbox mounts, use a RV8 manual clutch and flywheel... and that should be it?
Oh yes, and figure out a way to convert the clutch pedal to hydraulic to suit the box; I think I'll try the following method:
- MattMe
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
That RX8 gearbox solution is very tidy. That's an excellent setup with the hydraulic clutch system. Looks factory.
If you're converting to RV8 anyway, does it matter so much that the splines match a type 9?
Are the flanges for the prop the same too?
That ratios look ideal. I'm tempted to fit one now
You'll be having plenty of fun with that carb bolted atop your new 8 cylinder. I'm very pleased to see you decided not to keep the LPG conversion.
I think I'd have been tempted to go the EFI route myself, just for the easy life once you do get it setup. Set and forget type of thing, whereas that carb will take a bit of tinkering.
Keep us updated.
Keep us updated.
- Eurostang
MR2 SW20 (Missus's)
Quick update!
I have sourced an RX8 box with 70k on the clock.
Ended up selecting the 5 speed version due to availability (apparently they're stronger, not sure how true this is..) they're exactly the same in dimension and everything else, just one less gear. The ratios for gears 1-5 are identical to the 6 speed, too.
Here's the ratios with a 2.8 rear axle:
Here's the box (with the original capri propshaft popped in!):
My next step is to remove all the EFI and bolt on the intake and carb for a mockup run with the engine still sat in the landrover to get a feel for what may need adjusting.
I'm going to take the opportunity to get the rear axle out along with the fuel tank and fully rustproof the underside and then attempt to trial-fit the gearbox.
Here's another video for you guys
And here's the latest video mocking up the brake upgrade
EDIT: Fixed YouTube links
- Eurostang
MR2 SW20 (Missus's)
Another update;
I have the next week booked off work and planning to cram in as much work as possible!
I'm going to begin chopping out and grinding back all the areas of rust I can see, cut off the old wings and headlight bowls.
Rust proofing will consist of taking the areas back the bare metal and then treating with Fertan followed by a nice layer of Por15.
As for the underside she's still in great shape and has a good layer of the original dealer option 'Ziebart' which apparently was a thing in the 80s? I'll be covering with an additional layer of Bilt Hamber 'DYNAX'.
I have also started to strip off the EFI system in preparation to test fire the carburetor.
- Eurostang
MR2 SW20 (Missus's)
All,
EFI System totally removed and I'm about to test fire the carb setup!
And of course, another video update
- Eurostang
MR2 SW20 (Missus's)
Not updated here for a while; you can stay up to date via the youtube playlist I have going here https://www.youtube.com/playlist?list=P ... SsWAWZv_Ps
Since the last update the engine was pulled from the landy and I've begun to strip it down.
Here's the oily mess of my 3.9 engine
Removed from the Landy
Sourced another 3.5 rover V8 for the manual flywheel and just to have a spare!
Began to clean up and remove the crown wheel and pinion from my 1.6 rear axle
Finally! Slide hammered the half shaft out of the axle!
Celebratory beer
Began to restore the petrol tank
More to follow!
Celebratory beer
More to follow!
- Eurostang
MR2 SW20 (Missus's)
So a little more progress..
I've had to ditch the RX8 gearbox as the fitment to a V8 was pure nightmare. The lack of a removable bellhousing makes it difficult.
A T5 is the way to go but the prices for them in the UK waaay too high.It's actually cheaper to source in US from say craigslist and ship one over via an automotive transporter like so that's what I'm going to do.
In the meantime I've sourced a 5 speed type 9 gearbox from a 2.8 capri, removed the bellhousing and had a motor engineer make up a modified bellhousing. The modified bellhousing is from a BW35 or BW65 automatic gearbox fitted to rover p6b's
Looking good!
Also to note the axle is getting its V6 capri rear gears. I wanted a quaife LSD to go in at this stage but funds are short for nice to haves like that.
While at the motor engineers the V8 is being treated to:
Looking good!
- New cam bearings
- A new cam from Real Steel (Viper Hurricane)
- Cylinder bores honed
- Cylinder heads skimmed
- MattMe
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
Sweet!
Nice to see you making progress.
Do approve of an encouragement beer, but do not approve of Fosters.
- Eurostang
MR2 SW20 (Missus's)
Few more pics guys!
Prepping the dash for the new loom
Universal 24 circuit loom from the US, very nice bit of kit!
The new toy... an ultrasonic cleaner! every garage needs one
The block has returned from her trip to the motor engineers!
* New cam bearings
* Cylinders honed
* Oil galleries cleaned
* Core plugs
Come on!
Heads getting cleaned before they're skimmed down 1mm
Crank in and timing gears setLineToRejected
* New cam bearings
* Cylinders honed
* Core plugs
Come on!
- MattMe
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
Coming along nicely.
Interesting to see the ultrasonic cleaner results. What sort of cleaning fluids do you use in it?
- Eurostang
MR2 SW20 (Missus's)
Yeah that thing rocks.MattMe wrote:Coming along nicely.
It's a 15 litre capacity cleaner with 14 litres of water to 1 litre of regular Gunk Traffic Film Remover.
You can use regular tap water for most stuff like your tools etc.
Been a while since your last update, how are things coming along??
- Car(s): Ford Foucs 1.5 TDCi (Daily Driver)
Honda CBR 400 Import (Toy)
MK3 Capri 1.6 Laser (Restoration Project) - Location: Redditch
Loving this thread! Have toyed with the idea of a 3.9 myself! this is shaping up to be a mint project! keep up the good work pal
- Eurostang
MR2 SW20 (Missus's)
Many thanks!sparks wrote:Loving this thread! Have toyed with the idea of a 3.9 myself! this is shaping up to be a mint project! keep up the good work pal
I've not updated this thread in a long time in favour of doing it in video stages; check out my youtube channel at https://www.youtube.com/playlist?list=P ... SsWAWZv_Ps
