Mk3 Track/Race Car Build - Picture Heavy NOW!
Will01
Alfa 156 GTA (Daily Driver)
Alfa 2.4JTD Sportwagon
Mini Cooper S (Wife's)
Old Jags & Riley's for fun
Re: Mk3 Track/Race Car Build
Post by Will01 » Wed Apr 27, 2016 7:26 am
Will01
Post by Will01 » Wed Apr 27, 2016 7:35 am
I am sure you guys can appreciate there are alot more pictures. I just have chosen the main steps, there are over 500 pictures of every little thing i have done over the years.
I have only ever managed a few days a month, but in recent months i have had help from family to help with grinidng and painting which was a massive help. I can start to see the light at the end of the tunnel with this build now so all is well.
As you can see front compression struts off Escort Fitted with my own homemade mounts. I did alot of reinforcement in this area to support aswell.
I have modified a crossmemeber to hold the in situ adjustable TCA's aswell.
The front radiator supports have been removed to make way for a large radiator and to aid cleaning of that local area.
The shell has had alot of panels replaced and made. Also made up quite alot of reinforcement panels for the cage and cross braces etc aswell. But more is to come.
The interior is satin black to cut down on glare and is fitted with a full 6 point safety devices cage. I still need to get seats so i can finally fit the weld in rails and then i can start welding on the anchor points for the harnesses.
The engine bay is just a teaser for the rest of the car in signal yellow :)
Craigorypeck
Chevy Cobalt
Post by Craigorypeck » Sat Apr 30, 2016 3:28 pm
Damn fine work.
What are the main advantages of running compression struts?
:spam:
Will01
Post by Will01 » Sat Apr 30, 2016 5:44 pm
In conjunction with the in situ adjustable tcA's and the in-situ adjustable compression struts, i have a fully adjustable front suspension setup for Camber, Castor & Track :)
Also under braking etc it also keeps the strut where it should so keeps the alignment spot on under hard abuse.
I still need to get the threaded sleeves for the strut conversion up front. Then i will tie into adjustable top mounts to give me even more control of camber and castor.
Everything is adjustable as can be.
Will01
Post by Will01 » Sat Apr 30, 2016 9:30 pm
Some insight into Stages of Brake packages i am building and have at disposal.
Standard Capri non-vented discs with M16 Calipers, we all know this setup is pretty crap.
Bilstein suspension legs with Vented discs and spaced M16 calipers taken off a broken Brooklands, this worked really well on my last 2.0 GL.
Caprisport 280 GTR Front 285mm discs and Mondeo calipers with Sierra rear calipers and non vented rear discs.
Brembo 300mm front discs option for when the V8 is fitted, using Alfa 156 GTA 305mm Brembo calipers, i will upgrade the rear when required.
I am ditching the servo entirely and using a bias box setup. I will run separate master cylinders obviously for front and rear split and will combine with a Wilwood proporrtioning valve. I will also run a master cylinder for the handbrake circuit.
Because i am not using a servo i have modified the brake pedal to have adjustable ratio if required. This will depend on driver and also caliper setup. 3 different settings available and will be easily switchable.
Will01
Post by Will01 » Sat Apr 30, 2016 9:58 pm
Few more brake pictures
Longer studs fitted after this photo
And if i need them later, here are the Alfa calipers
Craigorypeck
Chevy Cobalt
Post by Craigorypeck » Sun May 01, 2016 6:16 pm
You have quite the selection there.
So if not using servo and going with bias box and two separate master cylinders. Why the need for the proportion valve?
And if running a hydraulic handbrake what stops the pressure heading to the front brakes too?
I have similar rear brakes from a mustang, they look identical with the spring loaded lever mechanism that's operated by handbrake cable . But finding and modifying cables and such might be a pain.
:spam:
Will01
Post by Will01 » Sun May 01, 2016 8:52 pm
The pressure will not run to the front brakes as the rear brakes are on their own circuit with their own master cylinder. Hydraulic handbrake is only really for launching and maybe for having a laugh when required..
The proportioning valve is for when running different front setups, means i can vary rear pressure when required e.g. swapping from 280 setup to 300 setup. plus it also means i can be a little lazy with rear setup and have more finite control of rear system pressure.
The cables are a little pain to setup, however since the rear setup is caprisport, they offer a cable kit for the rear.
I may end up upgrading the rear setup in future to use a vented discs, but i don't think it is a necessity at the moment
Craigorypeck
Chevy Cobalt
Post by Craigorypeck » Sun May 01, 2016 11:04 pm
Duh.. yeah of course they are on a different circuit. ...
Sounds like you have all angles covered!
:spam:
Will01
Post by Will01 » Mon May 02, 2016 11:35 am
We will see. I just keeping the car as adjustable as possible so we can fine tune it once it is built. At the moment i only have rough calcs to go by, nothing is certain until the car is a whole entity. I may even find certain things a hassle and remove them if needed.
Will01
Post by Will01 » Thu May 05, 2016 11:58 am
So this part is more about suspension.
I have already briefly touched on the Front sus setup, however there is alot more to it and also alot more which still needs to be sorted.
The Front suspension will be running In-Situ Adjustable Compression Struts & In-situ adjustable TCA's. I decided that i want to only use Rose-jointed mounts rather than PU bushed parts. Basically it means all rubber or PU bushes have been removed from front all together. Except maybe the ARB's, but that is still yet to be decided upon.
The front struts i am converting into height adjuustble and also damping adjustable coilovers. I will use a GAZ insert up front.
As for the ARB i will still use, but have a twin 20mm ARB setup, maybe change in the future, but i have bars lying around so i thought i would just use them. These will be joined to each other with brace clamps and i will also have a method of adjusting stiffness by varying pickup point. An adjustble droplink will then be joined to the strut underneath the height adjustable platform.
At a later date these will be replaced with GAZ Gold full coilover units with external reservoirs, but i will tie that in with the 300mm disc upgrade. This is because the struts i am converting are already machined ready to accept Caprisport GTR280 kit.
The rear suspension i want to keep more secret, but it will use SIngle Leafs which will be PU bushed with very hard bushing. I think they are 92Shore A hardness race bushes.
These will be tied in with GAZ Gold coilover units with soft helper springs. THese are rate adjustable, but i decided to go with rubber bushed end rather than rose jointed ends.
The rear arb will be ditched and i will run my own are which will be adjustble for stiffness by having moving pickup, but i will also be able to change the thickness of the arb and make big stiffness changes if required.
Eventually i will run a fully adjustble watts linkage, but i am behind designing this and this will take a while on its own.
The rear axle will be braced with an Escort 8mm Tarmac brace and then tied in with a Tickford style rear diff cover. that should help stiffen the rear axle. But i want to also try to lose as much weight as possible as this does inhibit performance of the suspension greatly. The watts linkage will help greatly anyway as it will reduce movement and also help to suppor the axle weight. This may help reduce unsprung mass slightly.
Craigorypeck
Chevy Cobalt
Re: Mk3 Track/Race Car Build - Picture Heavy NOW!
Post by Craigorypeck » Thu May 05, 2016 11:13 pm
I take it your using a drop linked rear arb? This will have removed any twist resistance your axle had from Factory. Im using an under axle arb from camaro with drop links then using some home made caltrac style torque arms to deal with axle rotation during acceleration.
I have a watts link installed and it will not support any weight... it will only stop axle movement from side to side no other parameter will be effected by a watts.. well apart from roll center. The lower the center pivoting propeller the lower your center of gravity.
I love those helper sprung rear shocks!
:spam:
Will01
Post by Will01 » Fri May 06, 2016 7:33 am
Drop linked arb yup
Under axle arb is exactly what i am going for, interesting you say it is off a Camaro, may have a look at one of those.
Can you post a picture of your setup please?
I agree it won't support axle weight and i must have been off writing or thinking something else haha whilst writing. What i meant is that the watts linkage bars do not add much weight, they do add some, however the pivot points are areas of rotation and can be largely ignored. Although i will be running what some people call a reversed Watts. Easy explanation is the roll centre will not be fixed on the axle, but on the body.
The GAZ rear shocks look great and come from advice given by Mark @ GAZ. He used to race a Mk3 Capri and recommended the setup.
Basically i want to keep leafs. Maybe one day when the front hangers rust out i will make the change to 4 bar.
MattMe
Car(s): Mk3 2.8 injection
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
Post by MattMe » Fri May 06, 2016 9:27 am
Looks as though it's all starting to come together now :cheers:
Those front discs look huge next to the standards. :shock:
Will01
Post by Will01 » Fri May 06, 2016 11:43 am
Just wait for the 300mm discs against the 280 kit haha!
Yes i think we ahve finally just about got to the starting to bolt it all together stage. Well that is if i wouldn't keep fettling things haha.
in one way i want to get it on its wheels, but then again i don't want to rush it, as i want it to be right. Another couple years off completion i reckon.
QuadCamCapri
Car(s): Capri 'Classic Thundersaloon'
5.0 32V Cobra V8 and E34 Touring
Post by QuadCamCapri » Fri May 06, 2016 7:42 pm
Lots of good work done there and great to see lots of pics.
Looking forward to seeing it all in Signal Yellow 8-)
My in-car race video Cadwell Park 1995 Capri V6 vs 2x V8's
http://www.youtube.com/watch?v=fUSBcLhI ... gvD3_PeHIA
Craigorypeck
Chevy Cobalt
Post by Craigorypeck » Fri May 06, 2016 8:09 pm
Here's my watts but it's in standard guise and not a chassis mounted crank.
I've got some gussets to weld in and a few other areas to tend to but it can be completely unbolted from the axle to gain access to diff and the frame unbolted from chassis.
The rear arb I was trying to source at the junk yard and had a few rusty stock items from various cars and trucks that use 8.8 rear axles but I ended up using a camaro job that a fellow capri nut called Vernon over on Capripower used.
His build is very good and he had already carried out the ideas that were floating about in my head so credit to him for finding the arb.
I've got no pics yet... I ordered it over a month ago and its still not here. Google hellwig 5824.
:spam:
Will01
Post by Will01 » Fri May 06, 2016 8:45 pm
Some good work there with the watts linkage. I did consider something similar to start with, but it also make it slightly more difficult with adjustable roll centre.
The removable mounting bars for watts are exactly what i had in mind for my design watts link. I like the idea of being able to remove when needed. Keeps it more flexible in long run.
The arb setup looks interesting aswell.
Trying to get really stuck in this summer before my wifes Maternity leave finishes and then everything will slow down again! Doh!
Going down south in a few weeks and getting fitted out with bucket seats for my wife and I, then the seat rails will get welded in place and i can start plumbing the brake lines for the driver position etc
Will01
Post by Will01 » Mon May 09, 2016 11:35 am
Weekend didn't get much done, however i did finally get to put my tube notcher to work. This really is a fine piece of design. Soo simple and works great.
For everyone's info it is an Eastwood tube nothcer and hole saw kit. I also used cutting paste on cutters. Clamped in a vice and then attached to eletric hand held drill. Probably better on pillar but i don't have one yet!
Got bit more work to do tonight, but just about ready to weld together the rear chassis strengthening brace ready for bolting in.
Will01
Post by Will01 » Fri May 20, 2016 6:16 pm
Not done much, but went for a bit of a shop today in Demon Tweeks and bought a pair of Cobra fixed buckets with sidemounts for the Capri today.
Can't wait till i get them fitted up and then i can finalise the weld in seat rail position :)
