2.0 laser street sleeper.
Hi, I have finally taken some pics of the work in progress. I have had this car for about 6 years now, first order of biz was to get all the body work done and re-sprayed.
Now I have finally had time to upgrade the mechanicals- see pics.
was intending "light sand and slap on some hammerite" and then went a bit mad......
work almost finished on axle/diff.... painted, poly bushes on single leafs and ARB, poly bump stops and....
rear vented discs. brackets:
calipers:
NB you need to file about 1.5mm off the caliper bosses:
installed with discs:
and now under Brookie 15"
later this week hopefully I will be making up copper brake lines- need to practice with the flaring tool a bit.... master cyl is ready to go on as is the servo, then hopefully the front end won't be quite as stop-start.
calipers:
Re: 2.0 laser street sleeper.
brembos in the oven.
rear brake lines in place.
- Hot_Protein
- Car(s): I have a rusty shell. Made some patches. Now the welding.
Awesome. Good clean work going on here. Like the oven baked brakes.
Thx, I am trying Rustoleum combicolour on the brembos, having been advised that it's a bit better than Hammerite which is what I use under the car mostly, or caliper paint from Halfrauds.
Seems pretty good so far.
some pics, most front suspension has been overhauled and repainted, also poly bushes throughout, and Brembos ready to go on.
rusty under the arb brackets
arb painted
TCA's painted
arb brackets painted
suspension is all in place, pics to follow.
arb painted
TCA's painted
suspension mostly in:
arb ready to go in
tidied up and painted
all in except for the arb and hubs etc
arb ready to go in
Capri's can't be made to look like sleepers they're too mean.
People always assume my 1.6 is fast hahaMajor_Tom wrote:Capri's can't be made to look like sleepers they're too mean.
Since I got a capri I've said "over the moon" a lot more than ever before.
More work this weekend, almost back on the road:
new steering rack gaiters, found a bad split on the offside.
and stickers on calipers too.
I haven't got pics of the newly made up flexible braided lines and also all new front solid brake lines. Also washed the engine bay and pressure washed the outside.
Currently stuck with the offside strut which has holes for the caliper which are 1) stripped and 2) too oversize for helicoiling- so I am waiting for time-serts from the US- couldn't find a supplier here- the thread is 7/16 UNF and I have the correct helicoil but as it's a safety critical bolt I am going to time-sert both of them- hopefully the damn hole is not too big, the outside of the time-sert is 5/8 UNC.
Problem is I got the struts years ago on eBay and never checked these threads.
that looks like a really thorough and detailed work your doing there i like the painted parts they look smart. keep up the good work.
