2.8i Restoration my project ongoing
sheff
Re: 2.8i Restoration my project ongoing
Post by sheff »
sheff wrote: changed mine when I bought the car. The prop seemed to have a lot of side to side movement, thought it might smooth the ride out a bit. The bearing on mine was ok, but I changed it anyway. The problem was the rubber sleeve around the bearing which was worn where it contacts with the bearing. Unfortunately it didn't make any significant differences to how the car drove
Hi Neil,
Thanks for that info, much appreciated. How much movement does your centre bearing sleeve have now? If I push up at the join, Mine moves, probably, 15-20mm within the rubber housing. Does that sound excessive? I've never changed either the bearing or the housing, and there isn't a receipt for anything in the history, so I have no idea when these parts were last changed.
Sorry for the hijack, Mart! :)
Virtually zero movement Andrew, just a bit of flex from the rubber mount, looks like you need a new rubber. For what it cost you'd just as well change the bearing at the same time.
You'll find this useful http://www.capripower.co.uk/boardold/in ... opic=13290
Neil
Hi Neil,
sheff wrote: For what it cost you'd just as well change the bearing at the same time.
Yes, my thinking exactly. While it's all apart, I'm going to treat the prop to a repaint as well.
sheff wrote:You'll find this useful http://www.capripower.co.uk/boardold/in ... opic=13290
Thanks for that, Neil. It looks an easy enough job judging by that guide. Let's hope it turns out that way!
CapriLee
Car(s): Currently S1 RS turbo. Looking to buy a 2.8i capri.
Post by CapriLee »
Stunning resto :D
martinc92
Car(s): Capri 2.8 injection special (restoration) Isuzi D-Max pickup (daily driver) Hyundai Santa fe (for towing)
Post by martinc92 »
Hi Andrew,
Sorry for not replying, as i haven't been online for a while as I've been doing quite a bit of work on the house so the Capri has taken a back seat, as it were, since the summer.
Concerning your question, i do now have a smoother ride on take up of power since changing the centre bearing, but i have also changed my centre CV joint whilst the prop was in half as this also had slight play in it. This was a bit of a pain to fit as this wasn't genuine as you can imagine.
i am due to fit new bilstein gas inserts shortly and refurb rubber top mounts, as my N/S insert is sticking with a slight bumping on the nearside as well which i hope is the top mount. As you know both sides will get done anyway.
I also hear belated birthday wishes are in order - happy birthday mate :cheers:
Mart
martinc92 wrote:I also hear belated birthday wishes are in order - happy birthday mate :cheers:
Thanks Mart!
It's good to have you back on the forum, it's been too long.
I hope that the replacement of your inserts goes smoothly. I was reading a thread about Bilstein refurbishment on the turbosport forum, it might have some information of use to you.
http://www.turbosport.co.uk/showthread.php?t=157492
martinc92
Post by martinc92 »
Hi Andrew,
Thanks for the info and link. After looking at this it looks a pain, but i will still probably go for it and get the bits from Gartrac.
cheers
Mart
ESSEXV6ESSEX
Car(s): Car
Post by ESSEXV6ESSEX »
WOW Thats a really nice car and a great job you have done there. Very impressive.
brooky
Car(s): 2.0 Laser and XR4x4i.
Post by brooky »
Hi Matt, just been looking back through your photos, stunning work. I notice that on your exhaust at the rear it is supported on left side by rubbers direct on the floor hangers yet the right hand side has the wrap round bracket around the silencer. Is this how it should be as I have got mine hanging direct on both sides but the right hand side is not sitting correct so maybe I need to fit one of the silencer wrap round type fixings, I did get a set of exhaust fixings off the internet which did include a silencer wrap round bracket but didnt use it as assumed it was for a different model.
Ardmore
Car(s): Ford Capri 2.8i 82 (Summer Fun)
Toyota Hilux 3L TD 12 (Daily Drive)
Post by Ardmore »
Beautiful job, well done sir!
Oldskool_Ford72
Car(s): Capri 2.8 Special Capri 1.6L Series 1 Rs Turbo S2 Rs Turbo Mk2 1600 Sport Rep + 3 Mk3 Escorts
Post by Oldskool_Ford72 »
What a cracking looking Capri fantastic job you done :lowrider:
