lazer 1.6 project
- Car(s): Ford Capri 1.6 laser 1985 blue ( restoration project)
lazer 1.6 project
Hi all , just thought i'd share my lazer 1.6 project with you all
I had the car for about 6 months now and have been concentrating on the bodywork mainly
I have removed the rear leaf springs and replaced these and cleaned up the diff and painted, i now have new brakes all round , calapers,wheel cylinders,shoes,pads and some brake pads
rather than replace the wing i repaired it , a rust hole was found after cleaning up the area and a patch was welded in
the rust area has been repaired, a plate made up, welded up,welds ground back ,filled and primed , i was going to lead load the patch but was happy with filler.repairs to rear arch next .
Re: lazer 1.6 project
The rear arch is next, the rear part was in very good condition but the front was rusty , hidden by body filler
the rusty area was cut out
A repair patch was cut from an arch panel to fit exactly so it can be butt welded
then welded in
all finished off , only a small amount of body filler was needed due to the butt welds
then welded in
Great work, it's motivation to sort mine out.
Yeh once you get into it and get some results it feels
Good and knowing that it's all your work too , can't beat
A bit of evening work on the project in the garage .
looks great!
- Car(s): 1982 2.8i black over silver (good condition but not perfect)
well done sir, looks ace!
Laser
lol yep that looks good when you want to do mine lol
Top job, going to have to do similar work to mine, guess a crash course in welding wouldn't go amiss.. Can't wait till mine looks that good.
- Car(s): Capri 1.6 Laser , weekend driving
Exactly what I want to do too, just need to get someone with the skill to do it. Well done you looks fantastic
- Car(s): Ford Capri 1.6 Laser (1985)
Many congratulations. An excellent finished job.
Did you remove the tailgate glass during repair/painting, or did you manage to mask around the rubber ? (only asking as I will need to have mine repainted next year.)
Andy.
Andy.
Thanks , Carefully masked it up , couldn't if I was painting it a different colour really though , but this is the original colour
Laser. It's laser.
That is beautiful! Is that Cobalt blue like mine?
Thank you . No it's mineral blue .
