Mk3 V8 build
Re: Mk3 V8 build
Post by pbar » Thu Jul 05, 2018 9:44 pm
V8boss wrote:I've got some photos to upload, can anyone give me a pointer
2. Click Choose Images
V8boss
Car(s): Mk3 Capri with Boss 302, Tremec, IRS, RX7 front suspension
2x Mk2s donor cars
XY falcon, 351 V8, 4 speed AOD box and 9 inch
Re: Mk3 V8 build
Post by V8boss » Thu Jul 05, 2018 10:13 pm
Try this....
Image042 by paul nielson, on Flickr
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Thu Jul 05, 2018 10:17 pm
Image041 by paul nielson, on Flickr
Image021 by paul nielson, on Flickr
Photos are a bit backwards, but we went from green and fibreglass and scruffy to red and shiny :D Trying to do a bit each day, am currently working on the concentric release bearing set up, new flywheel and new clutch, should have that all buttoned up early next week, then waterpump, alternator brackets and harmonic balancer after that. Have also been working on the power steering lines for the mazda steering rack, have struck a bit of a roadblock there that needs sorting.
rshyndy
Car(s): Ford Escort XR3i MK5a, Lexus is200se
Re: Mk3 V8 build
Post by rshyndy » Sat Jul 14, 2018 8:12 am
Looking good mate. Love the colour. It's going to be a beast when it's completed
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Tue Aug 14, 2018 5:15 am
Engine now mounted on subframe (temporarily), power steering lines are started, clutch, hydraulic slave cylinder, flywheel and alternator bracket all sorted, and installed the front crossmember for the final time (hopefully) today.
Image075 by paul nielson, on Flickr
Image073 by paul nielson, on Flickr
Re: Mk3 V8 build
Post by D366Y » Tue Aug 14, 2018 9:46 am
Looks like it's coming along well! Loving the shiny engine as well :cheers:
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Wed Aug 15, 2018 4:04 am
Image002 by paul nielson, on Flickr
Alternator and bracket finally done, upgraded the internals to a 120 amp unit to cope with the Astra power steering pump, fans, MSD and assorted electrics.
Re: Mk3 V8 build
Post by D366Y » Wed Aug 15, 2018 7:37 am
Awesome stuff, look forward to seeing it in the car, will look sweet as!
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Thu Aug 23, 2018 1:26 am
Believe it or not, this lovely piece was a block of billet aluminium yesterday. Not my work sadly, I got a local machine shop that I know to spin it up for me, its a shame that it sits low down where no one sees it!
Image027 by paul nielson, on Flickr
Image028 by paul nielson, on Flickr
Image029 by paul nielson, on Flickr
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Thu Aug 23, 2018 8:24 am
Been beavering away at this for the last few days too, power steering bracket for Astra electric pump.
Image001 by paul nielson, on Flickr
not quite finished, but getting there.....
Will01
Alfa 156 GTA (Daily Driver)
Alfa 2.4JTD Sportwagon
Mini Cooper S (Wife's)
Old Jags & Riley's for fun
Re: Mk3 V8 build
Post by Will01 » Thu Oct 04, 2018 12:08 pm
Nice work, what have you done with the motor?
Re: Mk3 V8 build
Post by Jasonmarie » Thu Oct 04, 2018 12:26 pm
It’s coming on at a fast pace , and looking better then new . :beer:
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Thu Oct 04, 2018 7:23 pm
Jasonmarie wrote:It’s coming on at a fast pace , and looking better then new . :beer:
Well, the only genuine ford part on the whole engine is the cast distributor hold down bracket and an alternator bracket boss, everything else is aftermarket. :D The block is a 4 bolt Siamese bore Boss block, the heads are aluminium Edelbrock heads, Forged pistons, H beam rods, Steel eagle crank, roller rockers, Ferrera valves, Crow cam, etc etc. Makes about 400 HP at the crank, revs all day to 7000 rpm. Built for torque and horsepower, it pulls from about 1800 rpm, in the windy parts of a special stage you just drive the car like a jetboat, on and off the gas in third gear, great fun!
Re: Mk3 V8 build
Post by Jasonmarie » Thu Oct 04, 2018 7:27 pm
What a Engine I bet it sounds so nice , any chance of a quick video if you can as that’s does sound so nice . And 400 hp that will leave a Porsche standing and a lot more . :heart: it . Thanks for the update . :cool:
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Thu Oct 04, 2018 7:48 pm
Sadly no video of it running, it used to be in my MK5 cortina before I sold it, but i held onto the engine. Once shes up and running I'll def upload some vids of it going.
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Fri Oct 05, 2018 9:43 pm
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Fri Oct 05, 2018 9:50 pm
A visitor came today! Not much to see here, but progress is being made. Pedal box is made up, painted and installed, steering column and shaft painted and installed too. LHS suspension is all cleaned up and installed along with the new hubs and brakes, RHS is started and should be all together on Monday. It’ll be rolling then, and I’ll put it on a hoist to investigate why my power steering is leaking, hopefully just a loose fitting. If not, it’s easy to pop it out before I install the engine, shit of a job afterwards, so nows the time to sort it. Engineer comes for his first visit next Friday for first inspection, hopefully he’s happy with what he sees I’ve done, otherwise I’ve got some issues with making it Road legal :shock:
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Fri Oct 12, 2018 9:04 pm
Image3B41E820-A794-4DB2-9FDC-4003533CA7B6 by paul nielson, on Flickr
Progress! Suspension all fitted, still got brake calipers to reco, but that can come later. Engine and box are all mounted, got to remove the gearbox crossmember again for a bit more work, but that’s easy. Engineer has checked it over, and picked up a few small issues, but nothing too hard to remedy. Still got plumbing, cooling system, wiring, seats and harnesses, exhaust, driveshaft, glass, interior to go!
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Fri Oct 12, 2018 9:06 pm
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sat Nov 10, 2018 11:55 pm
Bit of progress, gearbox mount sandblasted, primed and painted and installed. Engine is finally in the hole properly. Headers are all bolted up and collectors fitted. Radiator is sitting there, along with the top panel which is all painted up too. Might change it yet, yet to decide. Also started adding straps to the rear strut tops like the engineer wanted. Not sure why, but it’s not welding that well, keep getting contamination in the welds.
ImageB65E7F34-A968-474B-92AE-807164772BDD by paul nielson, on Flickr
Image8113EF7B-0004-4D9F-BB3A-A17F9D3A706F by paul nielson, on Flickr
ImageD5183F82-1C16-4F65-B8F8-873A86C2F421 by paul nielson, on Flickr
