Mk3 V8 build
V8boss
Car(s): Mk3 Capri with Boss 302, Tremec, IRS, RX7 front suspension
2x Mk2s donor cars
XY falcon, 351 V8, 4 speed AOD box and 9 inch
Re: Mk3 V8 build
Post by V8boss » Fri Apr 13, 2012 2:09 am
Ok, try again...
Need to finish smoothing the welds, but you get the idea.
Beakster
Re: Mk3 V8 build
Post by Beakster » Fri Apr 13, 2012 2:40 pm
Fantastic :) what plans for the interior, are you going to have a custom carpet made up or will it be more minimalistic inside?
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Fri Apr 13, 2012 11:01 pm
No carpet, will be fairly smooth once I've finished, and then I'll paint the interior silver or white, rollcage and all. I'll bolt some alloy treadplate to the floor and make a footrest for the navigator as well. The back will get a helmet hammock, sparewheel carrier, towrope and first aid kit (mandatory for our regs). Pretty bare, but will do the job :drive:
drtdgg
Car(s): 347 Windsor powered mk2
Re: Mk3 V8 build
Post by drtdgg » Sat Jun 09, 2012 7:25 am
any updates? i find this one quite enjoyable as im doing a 302 conversion as well
mgentry90
Re: Mk3 V8 build
Post by mgentry90 » Sat Jun 09, 2012 9:32 am
i agree, keep checking for updates on this one but dont get any :(
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sun Jun 10, 2012 8:05 pm
Dont worry guys, there is a BIG update coming, but will be another couple of weeks away. I think it will be worth the wait...... :D
Paul
MK1 1UZ
Car(s): 1973 mk1 V8 project, 1985 sierra xr4x4 rally project
Re: Mk3 V8 build
Post by MK1 1UZ » Fri Jul 06, 2012 5:50 am
What Series RX 7 front end did you use? what kind of mods did you have to do to make it fit in? Did you use the Capri steering column, or alter the RX 7 one to suit? Sorry for all the questions, am building a v8 capri and was told this was the way to go to make the conversion WAY easier
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sat Jul 07, 2012 5:45 am
Used the subframe from a series 4 RX7, had to cut into the chassis rails of the capri, and also cut out the subframe and weld in some angle iron, all to make the subframe sit at a good height. Used the RX7 column, and the short shaft from a mazda 929, then made up brackets to make the column bolt to the dash. Will try and find some photos of it all if youre interested. This info was all given to me by a guy who stucka 1uz into his Mk1, and it works really well in his car.
MK1 1UZ
Re: Mk3 V8 build
Post by MK1 1UZ » Sat Jul 07, 2012 9:23 am
Pictures would be awesome if you don't mind uploading/sending them. will PM an e-mail address to you if its easier that way.
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sun Jul 08, 2012 11:11 pm
I'll load them up here, don't think anyone will mind seeing them. Won't be for a couple of weeks tho, as the car is still with the rollcage builder at the moment.
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sun Jul 08, 2012 11:19 pm
Speaking of which, he has sent me through some progress photos, shot through the front screen.
Main hoop, floor bar, harness bar and diagonal braces.
Through the drivers door, you can see the dash bar, intrusion bars, and the forward bars that go into the strut towers to add more chassis strength as well.
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sun Jul 08, 2012 11:21 pm
Just waiting on paperwork from Motorsport NZ now to homologate the cage, then I will get it back and continue to the next phase, floor and fuel cell in boot.
BMWcapri
Car(s): BMW V8 powered '81 Calypso
Re: Mk3 V8 build
Post by BMWcapri » Mon Jul 09, 2012 6:06 pm
Impressive fabrication, looking forward to seeing this thing out on the road/track!
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Sat Jul 21, 2012 7:03 am
Finally, an update! Got the call from my rollcage builder, ready to pick up. Went and got it with my mate Gareth today (he has a mad anglia with a 2 litre twin cam from a telstar that we gravel rally), and took it back to the workshop tonight. Hes done a brilliant job, all tig welded, goes forward into the strut towers, intrusion bars and heaps more. Sorry photos arent brilliant, just snapped some before I went home tonight.
More to come!
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Fri Jul 27, 2012 7:24 am
Not much progress since I got it back from the cage builder, but have sussed out my radiator mounts a bit, using Toyota Cynos lower radiator mounts of all things, they are shaped perfectly, saw them on a car that came through work and thought, that'll do! Have also ordered a set of pulleys for the engine, Ford Motorsport stuff, and it allows me to run a belt for the power steering set up. I used to use toyota MR2 electric pumps, but they are heavy and prone to failing. I like the simplicity of a mechanical pump too.
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Wed Aug 15, 2012 11:59 pm
Little bit more progress. Made up my radiator mount, which has been longer than I thought something so easy should take. Used Toyota lower mounts and fabbed my upper mounts onto my custom rad support panel, the nuts that hold the panel on are rivnutted from underneath the headlight buckets, so rad removal is quick and easy. Also means that engine removal is easy too. (not that I should be doing it too often!)
I've also been working on changing the belts to a serpentine set up, same as E series or AU falcons. Picked up a brand new timing cover last night for 40 bucks! Feel almost guilty getting it so cheap, someone has also polished it, so nice to have the extra bling. I will then use an AU waterpump, change the drive on my alternator to a 6 rib pulley, and then mount up a power steering pump off the passenger side cylinder head. Have been scouting at pick-a-part and saw one off an astra of all things that looked like it would do the job well.
Progress is slow but steady I guess.
Mohsin
Car(s): Ford corsair 2000 deluxe crayford pinto powered 100bhp
Ford corsair 1700 deluxe (restoration project) 3.0 V6 130bhp
Ford corsair 1500 track car (Cossie powered project) 330bhp
Ford sierra 4x4 cosworth 380bhp
Ford sierra cowsorth 3dr track car 440bhp
Nissan skyline R33GTR 700bhp
Re: Mk3 V8 build
Post by Mohsin » Thu Aug 16, 2012 2:05 am
Sweet project there mate.
I just love those manifolds :D
I saw a similar capri to that at Tickover in Dartford a few weeks ago, had a similar colour.
It was dark green on the outside and I think the bay and interior was painted silver.
Was a good colour combo imo.
Big Boys Drive Big Toys
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Tue Oct 02, 2012 8:16 am
Been busy lately, havent updated much sorry. Have made a power steering bracket, used an Astra pump. Also mounted my alternator and sourced a new pump. Made up an idler bracket out of some 4mm plate and some crush tubes. Also modified a nissan power steering reservoir and mounted that with some rivnuts to the inner guards. And then bought a couple of Jaz overflow tanks and mounted those as well. Looks nice and symmetrical in the bay.
Best news is that I scored a set of 17x8 and 17x9 two piece BBS rims with a set of race slicks in good condition. They fit, but only just. So I am going to source a X pack kit from the UK. Sadly due to the exchange rate and shipping costs, it will cost me about 2 grand! Ah the joys of wanting to different from the pack.............
mgentry90
Re: Mk3 V8 build
Post by mgentry90 » Tue Oct 02, 2012 11:23 am
looking great, been waiting for an update on this one! 2k for x pack? surely there is a cheaper way for you to get it done. get a fabricator to make a set up? just an idea, dont know how likely it is to happen.
hessu75
Car(s): Ford Capri Mk3 2.9EFI daily summer drive project
2.9EFI turbo engine project for the Capri
Re: Mk3 V8 build
Post by hessu75 » Tue Oct 02, 2012 1:39 pm
Just love the look already, even without the X-pack.
I am also bending a roll cage this coming winter inside my blue Mk3.
Minimalistic interior is pr0n.
Cheers from Finland
-Hessu-
