Black 2.8 project
- Car(s): Fiesta, laser ( under modification )
Re: Black 2.8 project
great project, keep up the work. how much did the garage thing cost to glue together?
The garage thing cost more than the car! The car with spare parts cost £500 when I bought it.mgentry90 wrote:great project, keep up the work. how much did the garage thing cost to glue together?
The roof is relatively expensive as I used polycarbonate sheets and the proper joining strips etc. The timber is all treated timber as its partially open to the weather. I forget the exact cost but it could have been done cheaper although its surprising how quick costs add up when you include gravel, sub base, post set etc
Did a little more on the rear light - doesn't look concave any more
DSC_0082 by Peter Smith, on Flickr
Finished nearside A post
DSC_0075 by Peter Smith, on Flickr
Took a drill and wire brush to the nearside floor rust. I can live with this
DSC_0070 by Peter Smith, on Flickr
This was the spare wheel well
DSCF1891 by Peter Smith, on Flickr
Now looking a bit better
DSC_0081 by Peter Smith, on Flickr
Nearside door hinge area was a little crusty
DSC_0083 by Peter Smith, on Flickr
so started cleaning the spare that came with the car
DSC_0076 by Peter Smith, on Flickr
Primed and fitted
DSC_0079 by Peter Smith, on Flickr
Rubbed down offside rear
DSC_0078 by Peter Smith, on Flickr
and into primer
DSC_0080 by Peter Smith, on Flickr
Probably be too cold, damp and dark to get much more done to the body for a while
Primed and fitted
and into primer
Nice work Peter.
Its looking better and better all the time mate.
atb Paul
atb Paul
Thanks Paul, appreciatedchap280 wrote:Nice work Peter.
atb Paul
Needed an 'inside job' this week as the evenings were grotty so started cleaning the front bumper
DSC_0084-2 by Peter Smith, on Flickr
DSC_0088 by Peter Smith, on Flickr
Today though the sun came out and it was mild so I liberated the dusty hatch so I can work on that later
DSC_0087 by Peter Smith, on Flickr
and was also able to do a little more to the boot floor
DSC_0084-1 by Peter Smith, on Flickr
and get the rear valence in primer
DSC_0090 by Peter Smith, on Flickr
Bit cold for body work today so popped into the garage to make a start on the engine. The previous owner told me he had cleaned the sludge out of the sump and he removed the core plugs and gave me a new set to put in but I thought I would strip the engine as I have no real idea what he had done. So, sump off
DSCF4318 by Peter Smith, on Flickr
Looks like the inside could do with a bit of a clean although a brand new thermostst housing has been fitted which will save a few quid
DSCF4319 by Peter Smith, on Flickr
Crank liberated
DSCF4320 by Peter Smith, on Flickr
Pistons needing a bit of a clean and they;ll get some new rings which I bought a few months ago
DSCF4321 by Peter Smith, on Flickr
Bare block ready for cleaning. It will get painted up too.
DSCF4322 by Peter Smith, on Flickr
Found that the connecting sleeves from the block to water pump housing had corroded
DSCF4323 by Peter Smith, on Flickr
22mm pipe was too small but 22mm pipe connectors, cut down and lightly sanded are perfect
DSCF4324 by Peter Smith, on Flickr
Crank liberated
- Craigorypeck
top job peter!
Nice work peter
Getting to the part of the year wher eI have little free time
Outside I've removed the last of the stripes
162.158.18.81
Inside the cam and tappets are out of the engine awaiting a clean
DSCF4325 by Peter Smith, on Flickr
DSCF4326 by Peter Smith, on Flickr
Started cleaning the block
DSC_0092 by Peter Smith, on Flickr
and gave it a light hone
DSC_0093 by Peter Smith, on Flickr
New core plugs
DSC_0094 by Peter Smith, on Flickr
and etch primed
DSC_0096 by Peter Smith, on Flickr
Also started on the water pump housing
DSC_0095 by Peter Smith, on Flickr
DSC_0097 by Peter Smith, on Flickr
162.158.18.81
New core plugs
and etch primed
Nice work Peter
Had a bit of time over Christmas but needed to spend a couple of days on the other Capri so not much progress on the project
Anyway, rusty accumulator tarted up
DSC_0053 by Peter Smith, on Flickr
DSCF4333 by Peter Smith, on Flickr
Sump sorted
DSC_0098 by Peter Smith, on Flickr
DSCF4337 by Peter Smith, on Flickr
Pistons and shells cleaned
DSCF4335 by Peter Smith, on Flickr
DSCF4334 by Peter Smith, on Flickr
Camshaft and tappets cleaned
DSCF4328 by Peter Smith, on Flickr
DSCF4329 by Peter Smith, on Flickr
Front housing sprayed
DSCF4332 by Peter Smith, on Flickr
Crankshaft bearings cleaned
DSCF4330 by Peter Smith, on Flickr
Block painted, crankshaft cleaned and back in situ
DSCF4331 by Peter Smith, on Flickr
Sump sorted
- jimmyted
Peter, you’re a machine!! Quality work.
Never have much free time in the early part of the year but just started getting back to the project. Since it's freezing otside I've carried on with the engine
Typical main cap
DSCF4338_zpscae9cd6e by Peter Smith, on Flickr
Cleaned up
DSCF4339_zpsf260e03c by Peter Smith, on Flickr
Grungy oil pump
DSCF4341_zps14619041 by Peter Smith, on Flickr
Strainer cleaned with new gasket
DSCF4342_zps6f8a7b83 by Peter Smith, on Flickr
Reassembled
DSCF4343_zps5a06d3ed by Peter Smith, on Flickr
Caps on and seal going in
DSCF4344_zps9407515d by Peter Smith, on Flickr
New rings on and pistons going back in
DSCF4347_zpse551c4a5 by Peter Smith, on Flickr
New rings have sharp ends!!
DSCF4346_zpsec25e020 by Peter Smith, on Flickr
Front casing coming together
DSCF4345_zpsf011b7c4 by Peter Smith, on Flickr
Typical main cap
Cleaned up
Grungy oil pump
Reassembled
- Car(s): Ford Capri 1.6GL (restoration project)
Lexus gs300 daily driver - Location: Coventry
This is looking great. How do you clean some of these parts? they come up like new. Are they shot blasted or just plain old elbow grease? Great job cant wait to see the engine back in.
ian_s wrote:This is looking great. How do you clean some of these parts? they come up like new. Are they shot blasted or just plain old elbow grease? Great job cant wait to see the engine back in.
Cheers mate
Good old elbow grease is the answer - thinners or WD40 and a toothbrush, some fine wet and dry and brasso wadding on the bearings. Getting there slowly
looking good peter now you can say you,ve put blood sweat and tears into the project will she be ready for CRAP
1st time I've viewed this thread Peter. Looking like some quality work you've been doing. Well done sir!
Thank you very much indeed Dave, most kindSmokeEm wrote:1st time I've viewed this thread Peter. Looking like some quality work you've been doing. Well done sir!
Don't know if it will be done that soon Dan. The 2.8 engine is all knew to me and was largely stripped when I bought it so I'm assembling from boxes of parts - which all need a damn good clean to boot! And if spring showed any chance of turning up I might make a bit more progress toolooking good peter now you can say you,ve put blood sweat and tears into the project will she be ready for CRAP
Any way, to help the engine rebuild I bought an engine stand
DSC_0109_zpsacc84a2a by Peter Smith, on Flickr
A bit more cleaning
DSC_0116_zpsadb4c416 by Peter Smith, on Flickr
DSC_0117_zps5b0baf4f by Peter Smith, on Flickr
Cam gear on, torqued and timing dots aligned
DSC_0118_zpsb10790ad by Peter Smith, on Flickr
Front case back in place
DSC_0119_zps9c12e218 by Peter Smith, on Flickr
Cylinder heads painted and rested in place
DSC_0120_zps43d35c70 by Peter Smith, on Flickr
Cruddy looking injectors cleaned
DSC_0121_zps07bc3091 by Peter Smith, on Flickr
DSC_0122_zps3642a829 by Peter Smith, on Flickr
Next were the cruddy push rods
DSC_0123_zps471dcff0 by Peter Smith, on Flickr
DSC_0126 by Peter Smith, on Flickr
The the equally cruddy rocker gear
DSC_0127 by Peter Smith, on Flickr
DSC_0128_zps9be07c7a by Peter Smith, on Flickr
New gasket
DSC_0129 by Peter Smith, on Flickr
Reassembled
DSC_0131 by Peter Smith, on Flickr
For a change of scenery it was down the shed with a heater to rub down what was obviously a replacement tailgate, being red under the glass seals, and apply some primer
DSC_0124_zps85b5612a by Peter Smith, on Flickr
DSC_0130 by Peter Smith, on Flickr
DSC_0125 by Peter Smith, on Flickr
New gasket
Reassembled
