the 3 ltr s project begins
simon.rob
Car(s): ford capri 3.0s ongoing restoration, white 2.8 injection and daily driver is a 2.0 seat leon fr
Re: the 3 ltr s project begins
Post by simon.rob »
some snaps i took on sunday :)
viewtopic.php?f=19&t=38301
simon.rob
Post by simon.rob »
Disaster! :( engines been stripped and needs alot! of work, including acid dipping, new heads and potentially new piston rings after a port bore and polish....so heres some pics of that and an alternator iv been working on..
anyone have a 3.0 block they know is working and doesnt need too much work doing to it ?
simon.rob
Post by simon.rob »
ok shell finally out of that workshop! now prepping for the spray!
windscreen fell apart during the move, anyone have one available ?
thanks alot
si
simon.rob
Post by simon.rob »
going for a paint :)
simon.rob
Post by simon.rob »
ok heres an update! cars still in paint/workshop having wing realligned and bonnet straightened, in the mean time iv been to capri gear (my dream workshop) and got some bits off martin including a windscreen that isnt fragmented :)
tidied up gearbox all bearings seem ok, selects all gears ( one of the push to reverse ones) will be doing a swap with someone for a 4 speed original ;)
been battling the surface corrosion on the headlamp holders spent a day doing just one :S so heres some pics:
some rubbing down later
hopefully next lot of pics will be of car :D
rousecapri
Car(s): capri mk3 3lt ghia(long term project) land rover discovery daily driver 2lt mpi
Post by rousecapri »
looking good!!
Bigger is better,there is no replacement for displacement
simon.rob
Post by simon.rob »
thanks bud! got a few pics of first 5 coats! :D
some pics of fuel tank and both headlamp frames..couple of dents in tank....anyone know the best way to clean inside of tank ?
thanks for looking :)
chap280
Car(s): capri 3.0s.
1948 5.7 chevy stepside
Post by chap280 »
looking great mate.atb paul
simon.rob
Post by simon.rob »
back from the spray shop :D
chap280
Car(s): capri 3.0s.
Post by chap280 »
really nice job mate.looks spot on,atb paul
turbo-mike
Car(s): capri 2.8, focus van, st focus
Post by turbo-mike »
looks dam good, only 1 thing your stipes are too high they should be in line with the bumpers not the bottom of the stripe following the fold in the side, hope it is not to late to remove them and lower.
mike
simon.rob
Post by simon.rob »
yeah :/ knew i should have done them myself, hopefully be able to salvage them at a later date or atleast remove them and get new ones :) still looks good for now..till bumpers are on :D
Ghia15
Post by Ghia15 »
Trust Mike to pick that one up.
Love the colour though and the stripes are a good contrast as well.
3
simon.rob
Post by simon.rob »
thanks dude its ford performance blue :)
simon.rob
Post by simon.rob »
few bits done, sunroof cable and conduit removed cleaned up and greased, found mud on the conduit which im guessing is why it was jammed in the first place. hammerite blue just for good measure :)
sunroof was a pig to fit spesh with the new seal, nothing a bit of vaseline cant cure :D
headlights and shrouds fitted also
will try get some pics of engine bay on friday when its light, cars back on old wheels and axle stands now ready for colder weather. glass gradually going in :)
rousecapri
nice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
simon.rob
Post by simon.rob »
thanks buddy! :D can you message me your number again please? i lost it just so i can get in touch about the gearbox exchange :)
thanks for looking!
si
simon.rob
Post by simon.rob »
some more pics :)
engine bay
under bonnet
inside tailgate
ok took the wiring out of the tescos bag under the dash to reveal a massive tangle of wires that have lots of broken/missing connectors :( been a bit savaged !
and sill guards
thanks for looking!
simon.rob
Post by simon.rob »
ok done some more bits to the car, both door frames, glass, handles etc are on,
front grill and bonnet leading edge trim is on,
found an engine wiring loom atlast!
can anyone identify these gaiters for me ? ?
and got some welding to do next to the seat mounts
rousecapri
no.1 gear lever
no.2 heater drain cover
no..3 and 4 clutch arm cover (depends which box you r using)
