Mk3 V8 build
V8boss
Car(s): Mk3 Capri with Boss 302, Tremec, IRS, RX7 front suspension
2x Mk2s donor cars
XY falcon, 351 V8, 4 speed AOD box and 9 inch
Re: Mk3 V8 build
Post by V8boss » Tue May 07, 2019 9:52 am
Bit more progress today. Fuel system time! So I removed the factory tank to install the IRS years ago, and I want to run a Jaz fuel cell. Because it’s a hatchback, I can’t have the cell in the car due to fumes and fire, it has to be enclosed in a box and vented to outside. So I got a mate with a sheet metal shop to make me up a big box, which consists of an upper and lower half. Today I mounted it all. I was going to use henk nuts, but they’re a bit of a pain to use, so I bought a new bigger rivnut tool instead, which does up to M10, drilled all the holes and mounted the lower box into the car, and the upper box to the lower. I also had to add an extra strap at the front to give me more places to bolt the lower box to the car, will do the same on the sides probably tomorrow. Pictures are a bit crappy, hopefully you get the idea.
ImageE4B4ECD0-CBAC-4EE1-8AD6-289297397175 by paul nielson, on Flickr
Image59EDA0AD-74B1-4B74-A05B-728C1BB6E391 by paul nielson, on Flickr
ImageAC2C8DFA-3154-4992-AEA7-B4C613A69BC3 by paul nielson, on Flickr
Image489CE0ED-CD85-4DAB-95A3-AAF735B4CF68 by paul nielson, on Flickr
ImageC303A1BB-B826-451E-8C02-52C6AC2325AF by paul nielson, on Flickr
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Tue May 07, 2019 9:54 am
By the way, I hate the colour that my painter did the interior in, I’m going to get him to redo it in the same red as the exterior
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Thu May 16, 2019 9:09 am
Did something pointless but enjoyable, and it gives me some motivation too.
Image7ECB4425-4138-4E23-9C8D-2AD3EB65F5A0 by paul nielson, on Flickr
Stuck her eyes back in, plus dropped the bonnet on to see how it all looks. Also installed the grill , discovered that the top of the grill was supported by the rad panel, which is long gone, so I’m going to have to make up something to hold the top in place. Might take the opportunity to move the grill back so it’s flush with the lights, will see.
Image86F1341B-D9F1-4570-976E-99F2A397B482 by paul nielson, on Flickr
You can see in this photo the extra that I put into the power bulge to clear the air cleaner, doesn’t look TOO garish, just tough 8-)
And one more for luck
ImageFAA5C880-6A94-4572-BE4A-D8440F10FCD2 by paul nielson, on Flickr
It was all a bit pointless, as it will all need to come apart again, but was certainly fun to see it looking like a car again
Re: Mk3 V8 build
Post by D366Y » Thu May 16, 2019 12:21 pm
Looking lovely!
Can't wait to see it when it's finished!! :cheers:
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Tue Jun 11, 2019 8:47 am
Still working on the fuel system, went a bit crazy on the weekend and bought some -10 Teflon braided fuel line, new pump and regulator,plus some fittings, over $500 in parts! :shock: started figuring out where the pump and filter would go tonight, got all the holes drilled and riv nuts inserted, looking good. Sorry no photos till I’ve got it all sorted. Also change of plans with the interior, I was going to pull it all apart (again!) and get my painter to redo the interior the same colour as outside. However I’ve realised that is going to add a whole heap of time to the build, and I want to get this thing up and racing sooner rather than later. I can always come back to the interior at a later time too. Let’s just call the current colour “primer” until I get back to it :D once the fuel system is sorted, hopefully by the end of this week, I’m moving onto the wiring, gauges and exhaust system, once those three are done, I’ll be able to touch the wick and see if it fires into life!
Re: Mk3 V8 build
Post by Not_Anumber » Tue Jun 11, 2019 11:10 am
especially like the subtly enlarged bonnet bulge. How did you do that ?
V8boss
2x Mk2s donor cars
Re: Mk3 V8 build
Post by V8boss » Tue Jun 11, 2019 8:23 pm
Basically cut it off at the base, but left the rear still attached, then lifted it up by about an inch and filled in the gap.
