Noel's car
Noel
Car(s): Capri 2.8i
M140i
Re: Noel's car
Post by Noel » Fri Apr 20, 2018 7:39 pm
Update since last year.
Front end now all done.
Grille and surrounds back to original plain black.
Bumpers powder coated and end covers done with HFVP
Nasty fuel filter clamp replaced with recon one from Caprigear:
Wheels refurbed and fresh tyres:
New tyres made huge difference, steering wheel shake 50-60 all gone and much less road noise!
Re: Noel's car
Post by Andrew 2.8i » Sun Apr 22, 2018 7:21 am
Hi Noel,
Your car is looking fantastic!
The Dunlop tyres look superb too, the tread pattern even looks right for the period. 8-)
Noel
Car(s): Capri 2.8i
M140i
Re: Noel's car
Post by Noel » Wed Jul 07, 2021 9:34 am
Hello been over 3 years so time for update. Long term rough running and low power finally had to be addressed.
I had compression tests done last year which found one cylinder with tight exhaust valve clearance and low compression. Re-setting tappet did not solve this, so knackered valve suspected.
Nothing for it but to book in head refurb, and finally got it done last month.
Heads came off for unleaded seats, new valve guides, new exhaust valves and new rocker shafts.
All top end parts and fittings cleaned up and re-painted.
Took opportunity to fit 6 new injectors too, plus new radiator and header tank (old one developed seep when disturbed).
Shiny bits look nice:
But what is most interesting is the state of the exhaust valves, here's the worst one that caused the compression loss. Very pitted, no wonder it didn't seal.
Injectors came out looking grimy but generally OK bar number 6, on which the nozzle has disappeared up the spout, very weird. Must have been hosing fuel in this one because you can blow straight through it. Normal injector opening pressure is about 40psi so gawd knows how it was running on this cylinder.
ANYWAY, after all this the running and general performance is back to normal, hasn't driven like this for years.
Re: Noel's car
Post by Jasonmarie » Sat Jul 10, 2021 11:27 pm
Glad you have sorted it sir
Re: Noel's car
Post by Andrew 2.8i » Sun Jul 11, 2021 11:03 am
It's good to hear that your car is now running well.
Where did you send the heads to have the unleaded conversion work done?
Noel
Car(s): Capri 2.8i
M140i
Re: Noel's car
Post by Noel » Mon Jul 12, 2021 12:05 pm
Jenkins Motor Engineers did all the work, and I just got all the extra bits together. They are in Whitton south west London - traditional engine machine shop, but with full garage facilities too so a one stop shop. Despite being very local to me, I never knew they existed until a friend showed me his Austin A40 engine that they had rebuilt.
All very much up our street.
http://www.jenkinsmotorengineers.co.uk/
