1984 2.8i special
- Car(s): Currently S1 RS turbo. Looking to buy a 2.8i capri.
Re: 1984 2.8i special
I used gasket sealer for the stat housing des . Always do tbh
I use a smear of grease either side of the gasket, less messy, prevents corrosion and allows the gasket to be reused time and time again. Put loads of grease on the 3 bolts also, as they tend to corrode after time.
Neil
Neil
2016 Ford Tourneo Titanium
2015 Subaru Forrester
Thanks guys... Not used the grease technique before Niel so worth a try... It's back to rusty brown again and temp issues so obviously I wasn't clinical when flushing out last time so I'll start over when I get chance...
Des
Des
All the new hoses fitted too Des and still dirty brown?
Not all buddy and yes still brown....CapriLee wrote:All the new hoses fitted too Des and still dirty brown?
Just picked him up from storage, 20 mins later on axel stands ready to start work in the Eve's next week...
If I get my backside in gear I might finally be able to book for one of the shows
[/URL]
[/URL]
Pulled the radiator out today and sent it for test and recore if required, I'll take the viscous fan off and fit a new water pump and thermostat. Drained as much crud as possible and I will renew the tired hoses etc, its entirety my own fault the brown sludge returned as I should have done it right first time round.. removed the degas tank which was desperate for a good sort out....loads of cleaning to do...
My rocker covers have seen better days they are distorted and don't sit correctly so got these back today, colour is not for everyone but I like it for the time being...
Des
[/URL]
[/URL]
[/URL]
Des
[/URL]
[/URL]
[/URL]
Looks ok to me Des
Thanks guys, I like them too....
Do we have a special section for irritating little previous owners bodge jobs....
Broken n/s engine manifold (stud tabs) bodged to make them look ok...
Snapped bolts in the water pump...blathered in crap inside and out in the hope it won't leak...
Water pump flange to pulley cast broken in two places...
Rear themostate flange lugs broken..
Pump Bolts are snapped flat in the timing cover so I'll drill and extract if I'm lucky, replace the manifold etc...
On the bright side It only small irritating stuff ...
[/URL]
[/URL]
Hi Des,
Sorry to hear of all the irritating little problems you are experiencing. Consider them character building!
My Brother did that once. He glued the snapped head back into position on the manifold! Some people...Bertie wrote:Broken n/s engine manifold (stud tabs) bodged to make them look ok...
Andrew 2.8i wrote:My Brother did that once. He glued the snapped head back into position on the manifold! Some people...
Hi Andrew
Naughty but Brilliant at the same time ....
Des
So this afternoon I did complete a compression check, flat cold and dry the readings were constant across 5 cylinders at 130psi and the other was 140 so I'm personally ok with that result and will carry on with the list of other works... Feel free to tell me otherwise...
Prop shaft center is goosed not over noisy but it's more like play doh so will attend to that. Pulled the cover off the diff which obviously stank and it's ready for a good clear out.... what replacement oil are you using guys..
Des
[/URL]
Des
[/URL]
Hi Des,Bertie wrote:.any offers re the best replacement oil welcome guys..
I used Miller's classic differential oil in mine. Whatever brand of oil you use, be aware that API GL5 is specified for that application.
Hi AndrewAndrew 2.8i wrote:Hi Des,Bertie wrote:.any offers re the best replacement oil welcome guys..
As always I'm greatfull for the correct info as I don't want to get it wrong for the sake of not asking...
Des
whilst awaiting parts the gunk was finally cleared from the radiator and the flow is now spot on so no need for a recore which is a nice bonus. Quick paint and ready to go..
[/URL]
[/URL]
Hang on!!! I think its different oil for the LSD axle. Check on the CCI website.Andrew 2.8i wrote:Hi Des,Bertie wrote:.any offers re the best replacement oil welcome guys..
I think you need this http://capriclub.co.uk/suspension-handl ... le-Shooter
Neil
Hi,sheff wrote:Hang on!!! I think its different oil for the LSD axle. Check on the CCI website.
Neil is quite right, I overlooked the fact that Des has a Special.
I think the CCI LSD oil is Castrol B373 SAE 90 Racing oil.
http://www.opieoils.co.uk/p-712-castrol ... -b373.aspx
Hi AndrewAndrew 2.8i wrote:Hi,sheff wrote:Hang on!!! I think its different oil for the LSD axle. Check on the CCI website.
Not a problem I should have said special....
Ive ordered the CCI kit along with a few other items so nothing lost and thanks for the info Neil ......
Cheers, Des
