Ford capri 1977 3.0s resto
tazla
Post by tazla » Wed Jun 24, 2015 9:12 pm
Hi thought id join in, im in the middle of a resto,a few pics of what ive been up toImageImage Image ,ImageImageImage Image Image[/URL[URL=http://s131.photobucket.com/user/meltaz ... F.jpg.html]Image]ImageImage Image Image Image Image Image Image Image Image ImageImage Image ImageImage Image ImageImageImage Image just needs a repaint then shove back together
Re: newbie here from oldham
Post by Fordoholic Nick » Wed Jun 24, 2015 9:24 pm
Hi mate,
Welcome to the forum :)
Thanks for posting up pics of your resto...WOW ! That looks absolutely stunning so far...cant wait to see the finished article. That engine is simply awesome...nice one !
Good luck with the rest of it but you obviously know what you are doing looking at the quality of your work...stunning... :applaud:
Post by pbar » Wed Jun 24, 2015 9:26 pm
Looks great. And welcome. Hope to see the car for real sometime, will you be going to shows?
tazla
Post by tazla » Wed Jun 24, 2015 9:49 pm
Fordoholic Nick wrote:Hi mate,
Cheers nick,itl be finished for next summer,just needs a good paint job,then shoved on stands,all suspension taken off,refurbed,paint the underside,shoved back on,put it all back. together, as easy as that :doh:
tazla
Post by tazla » Wed Jun 24, 2015 9:52 pm
pbar wrote:Looks great. And welcome. Hope to see the car for real sometime, will you be going to shows?
Next year hopefully,classic ford,tatton park,thanks mel
Post by Andrew 2.8i » Thu Jun 25, 2015 3:24 am
Hi Mel,
Welcome to the forum.
Superb work!
When you put it back together it's going to be better than new.
Keep up the good work,
Post by pbar » Thu Jun 25, 2015 6:26 am
tazla wrote: Next year hopefully,classic ford,tatton park,thanks mel
Great stuff :)
3 Litre Power
Car(s): 1975 Capri II 3000 Ghia factory manual, 505k kms, Sunset Red, BVR, B.I
1988 Ford Escort XR3i Cabrio, 177k kms, Red, Black Top ( Daily )
Post by 3 Litre Power » Thu Jun 25, 2015 9:16 am
Very nice , i like that you're keeping it all original too! :applaud:
:burnout:
Oil and Coolant guru
tazla
Post by tazla » Thu Jun 25, 2015 3:02 pm
3 Litre Power wrote:Very nice , i like that you're keeping it all original too! :applaud:
Cheers, im trying to keep it original,but struggling,like the servo is a mk3 2.8 item,but i need a girling servo and master cylinder,hard to get hokd of,ive got the mk2 reservoir bottle and red cap,but it doesnt fit the newer brake set up,
Post by Caprifan Rob » Tue Jun 30, 2015 5:52 pm
Wow, impressed mate. Like the rest of your work, that engine looks stunning. Fancy doing mine ... ? :D
Post by Andrew 2.8i » Sat Jul 11, 2015 9:33 pm
Your zinc plated parts look amazing.
Did you do the zinc plating yourself? If so, what plating equipment did you use?
All the best,
tazla
Post by tazla » Sun Apr 03, 2016 7:27 pm
Sorry Andrew megga late reply :oops: a company near me does it for me cheap,
I've not done nowt for months,but made another start ,took headlining out,wiring loom out,Image Image I'll check the loom and retape it ,I've baremetalled the prop Image Image etch primed it Image and on inspection it looks as though the prop was black but the ends and a few other bits were a cast colour and a few bolts were light blue,so me being me :headscratch: :( Image Image Image Image Image ,I think the loom needed to come out ,botched over the years Image,then thought balls to it might as well take the dash outImage ImageImage job done,I'm prepping the floors and repainting them this week,pics to follow cheers mel
MattMe
Car(s): Mk3 2.8 injection
Previously owned:
Facelift Mk1 V8
Mk3 2.0 Laser
Mk3 2.8i
Post by MattMe » Tue Apr 12, 2016 2:08 pm
Looking good there. It's going to be a stunner when you've got it all back together.
I'm North Manchester - do you mind sharing where you had the zinc plating done, if you'd recommend them?
Do you have a new headlining or just take your old one out carefully? I've got to get a new one for mine because it ripped :(
tazla
Post by tazla » Sat Apr 16, 2016 7:26 pm
Thanks,I'll get you the number and address,its in Oldham,they're really good,I carefully too k the original roo f lining out
tazla
Post by tazla » Sat Apr 16, 2016 7:44 pm
Oldham electro plating argyle street ,they won't take parts which are really rusty,uv e got go clean em up a bit,cheers mel
Post by Andrew 2.8i » Sat Apr 16, 2016 8:38 pm
tazla wrote:on inspection it looks as though the prop was black but the ends and a few other bits were a cast colour and a few bolts were light blue
In case you weren't aware, the blue paint on the bolts indicates that they are high tensile grade 10.9. Worth knowing if you're replacing them with new ones and are repainting them to match the originals. It's best to replace them with an identical grade, not 8.8 or stainless bolts.
Keep up the good work, the bits and bobs are looking good!
tazla
Post by tazla » Sat Apr 16, 2016 10:37 pm
I did t kno that Andrew,I'm going to paint the bolts,I painted the last ones on a resto,the exact match is ford monza blue , I've took the sunroof out,as it has surface rust on the underside and framing/mechanism,so Image stripped it down Image Image etched Image Image Image Image Image Image Image Image hope I can get it back together haha,
tazla
Post by tazla » Sat Apr 16, 2016 10:44 pm
Floors were in good nick ,just a bit of surface rust,they were all done on the last resto years ago,so an easy job to freshen up, Image Image Image Image Image cleaned up a few bits to take to the zinc fella Image ,getting there
CapriLee
Car(s): Currently S1 RS turbo. Looking to buy a 2.8i capri.
Post by CapriLee » Tue Apr 19, 2016 8:18 pm
Looking god mel :D
tazla
Post by tazla » Wed Apr 20, 2016 1:15 pm
Ta mucka :)
