My 1975 3.0 Ghia Manual "rolling restoration" ( pic heavy )
sheff
Re: My 1975 3.0 Ghia Manual
Post by sheff »
pbar wrote:Goodness Neil, how did you spot that!
I was checking out the Capri Wiki and I thought I recognize that car :o It has a fairly distinctive number plate and I remembered the vinyl roof wasn't standard. Then I just had to work out which post I'd seen it in :?
I'd be quite pleased if my car was featured on this site :D
sheff wrote:I'd be quite pleased if my car was featured on this site :D
As wiki pages can be edited by anyone, can you just add a photo of your car to the site, should you wish?
Well if you were an action man you would be the eagle eyes version :)
sheff
Post by sheff »
Haven't seen one of those for a while. I used to have the talking one with the pull string in his back......... Ahh good times :D
sheff
Post by sheff »
Surely not? If that's the case how can we trust the information :?
sheff wrote:Surely not? If that's the case how can we trust the information :?
:lol: Very funny, Neil!
3 Litre Power
Car(s): 1975 Capri II 3000 Ghia factory manual, 505k kms, Sunset Red, BVR, B.I
1988 Ford Escort XR3i Cabrio, 177k kms, Red, Black Top ( Daily )
Post by 3 Litre Power »
hmm i wonder who put it there??? :lol: i also put a pic of the engine on the Essex V6 wiki
https://en.wikipedia.org/wiki/Ford_Essex_V6_engine_(UK)
:burnout:
Oil and Coolant guru
3 Litre Power wrote:hmm i wonder who put it there??? :lol:
I think we might need more clues to go on! :lol:
Well played, Sir! Added exposure for your car.
sheff wrote:I used to have the talking one
Me too :D One of my favourites that was. He enjoyed all sorts of shenanigans in the garden.
3 Litre Power
Spent the whole day today changing both engine mounts , the gearbox mount and provsionally fixing the swaybar bushing that just slid out , it was all worth it the vibrations i had before are gone , money well spent :mrgreen:
:burnout:
3 Litre Power wrote: i also put a pic of the engine on the Essex V6 wiki
Unfortunately, your link doesn't quite work correctly. It's not hard to navigate to the correct page from the link though.
Here's the link to the Essex engine wiki:
All the best,
sheff
Post by sheff »
3 Litre Power wrote:Spent the whole day today changing both engine mounts , the gearbox mount and provsionally fixing the swaybar bushing that just slid out , it was all worth it the vibrations i had before are gone , money well spent :mrgreen:
Nice one! Did you notice much wrong with the mounts you removed? I was thinking of fitting a new gearbox mount on mine to see if it improved things.
3 Litre Power
some of them were abit wonky and had gone a bit soft , the one that gad the biggest effect was the gearbox rubber mount i got it from Burton
:burnout:
sheff
Post by sheff »
3 Litre Power wrote:some of them were abit wonky and had gone a bit soft , the one that gad the biggest effect was the gearbox rubber mount i got it from Burton
Cheers I think I'll definitely change the gearbox mount, looks the easiest to change and that support is crying out for a clean and coat of fresh paint :D
3 Litre Power
Yes specially the gearbox rubber mount made a big difference
:burnout:
3 Litre Power wrote:Yes specially the gearbox rubber mount made a big difference
What sort of vibration were you getting before you changed the mount? Was it progressively vibrating more the faster you went, or was it at a certain speed or RPM? Also, what was vibrating, the whole car or just the gear lever?
Thanks,
3 Litre Power
It vibrated only between about 40 - 50 km/h ,no particular rpm , and you could feel the gear lever vibrating but you could also feel the car vibrate under your seat , before or after that speed it was all normal , since i changed the gearbox mount it's really improved a lot certainly , after about 70 km/h you can't feel anything at all it's smooth as ever.
:burnout:
3 Litre Power
One weird thing is thought hat since i replaced the gear lever pivot ball , when it's hot or the tranny heats up it's abit rough to shift , any idea why?
:burnout:
sheff
Post by sheff »
I think the problem with the gearbox mounts is that they can get contaminated with oil from leaky engines and gearboxes causing them to go a bit soft. My car seems to shake/wobble slightly when I accelerate sometimes and I do get some vibration through the gear stick. I'm hoping a new gearbox mount will cure this. Burton seem to be the cheapest http://www.burtonpower.com/std-gearbox- ... t9400.html
3 Litre Power
To be honest when i pulled the gearbox mount out i was stunned at how bad it actually was , i'll post a picture when i can , it was really wonky looked like a proper :turd: compared with the new one , and yes i reccomend Burton the one i got from them was perfect.
:burnout:
