My Laser and 2.8i TT
- Car(s): v6 capri 1979
Re: My Laser and 2.8i TT
nice purple on the tt m8
bloody awesome them cars are! we've always said youve got a couple of tasty motors colin!
Nice cars. Did you push the front bumper in? it looks much neater like that how did you do it?
John
John
- Car(s): 2.1 laser
No, bumper is standard on standard mounts. It must be the angle that the photo is taken from or a trick of the light.
- Car(s): 2.1 laser
Nearly ready for the MOT... It's amazing what you can get done in the cold when you have holidays from work...
Just need arm rests...
Need to sort back bumper...
Then onto what you would think is a really easy job... spark plug change... jusk ask any TT owner how hard it can be...
No room for plug sockets here
Specially modded spanner
a 16th of a turn at a time and 10 minutes later the plug is out... just as hard to get the new one back in.... and number 4 isn't that much easier to get at either...
Had the build sheet tucked away in a folder from when I first got her...
- caulkie
- Car(s): Ford Capri 2.8i special,
co- own mk3 cotina - Location: isle of man
would a rachet spanner be better for the plugs Colin?
- Car(s): 2.1 laser
no, because it needs to be seriously cranked to get into the hex section of the plug... never found one that would even nearly fit. Clearance is tight and most ratchet spanners walls are just too thick.
I've spoken to so called Capri "Specialists" in the past who said they don't bother changing number 5 on the TTs because it's "too fiddly"... It's not really that hard now I have the "special spanner" sorted, but still takes best part of 15 to 20 minutes in +2 degree weather to change number 5... the other 5 take about the same time in total...
The spanner I use is actually 5/8" and is alot older than me... and I'm 32 soon... it is best on teh TTs to get the smallest plugs (hex size) as this makes number 5 a little easier... I only ever use NGK plugs too... currently trying BCP7ES which is the specified plug for the 230BHP cars as I'm running at around 8PSI.
- Car(s): ford capri 280 turbo technics weekend drive
hi i have tt myself and i am about to replace the spark plugs i have just bought BCP 6ES as stated on the tt plate, when i got the car they had motercraft in,they look the same apart from the tightning nut' ngk are smaller.
also where did you get the spanner any help will be great thanks
steve
steve
- caulkie
Fair enough colin, just a thought that was all mate, i got some rachet spanners from halford
s last year thought maybe they might bend enough to make life a bit easier, well keep up the good work on the TT, i look forward to the next installment
caulkie
caulkie
- Car(s): 2.1 laser
spanner was from my Dad's junk tools box... it's older than I am... best to look at car boot sales and autojumbles etc...
Looking to MOT it in 2 to 3 weeks time and tax it early Feb. Going to make sure it is all working as it should for Scotch Corner in March.
Feb will make it 8 years since I took it off the road for a little welding which turned into a major rebuild...
- Car(s): Mk1 GLX
ooh just noticed colin...you tell the time in the TT by the boost? Nice mod there
